CATS Suspension Delete
Old Jul 1, 2019 | 11:28 AM
pauledddy's Avatar
Default CATS Suspension Delete
Evening all,
I would like the CATS system deleted as I'm going for some aftermarket struts (don't want to hear people say about it being a bad idea please! As it's not what you think)
I've read that unplugging the ADCM will stop the engine warning light come on on the earlier 4.2 XKR's, I have a 5.0 and have read that the ADCM also controls the Electronic Rear Diff, so ideally i don't want to just unplug it and have done with it! Is there any work around this?? I've looked everywhere but can't find anything! I have SSD and a Mongoose cable..
Thanks in advanced!
Old Jul 2, 2019 | 12:18 AM
pauledddy's Avatar
Anyone have any information?
Old Jul 2, 2019 | 05:22 AM
pauledddy's Avatar
I've measured the resistance of the shocks, and found it to be 2.5ohms. If I put a resistor there would that fool the ADCM into thinking theres something there?
Old Jul 2, 2019 | 10:07 AM
Cee Jay's Avatar
You're probably not getting any input cuz people think you're a nutball.
Old Jul 2, 2019 | 10:19 AM
pauledddy's Avatar
It's to add air ride to it
Old Jul 2, 2019 | 10:32 AM
Cee Jay's Avatar
Yeah, there's another guy on the forum who did that also, Ridicrick is how I think the name is spelled. You could check out his build thread:
https://www.jaguarforums.com/forum/x...dition-196122/
Old Jul 2, 2019 | 10:51 AM
pauledddy's Avatar
He has the 4.2 non supercharged one! The 5.0 is different the way the ADCM works
Old Jul 2, 2019 | 02:08 PM
Ridicrick's Avatar
That resister idea could possibly work. At least it makes sense in my head. I watched one of the Daily Driven Exotics youtube videos awhile back where a guy at AGX (Avant Garde Exotics) used a resister for a similar issue and it fixed it.
Old Jul 2, 2019 | 04:52 PM
pauledddy's Avatar
Yeah that's what I was thinking. I did a resistance test on the shock and it came it at 2.6ohms. So, I've made a ~2.6 ohm resistor with 4 10ohm resistors in parallel lol. Will give it a go tomorrow and see what happens!
Old Jul 3, 2019 | 07:58 AM
pauledddy's Avatar
Tried the resistor, it didn't work unfortunately.
Found out they've misspelled Adaptive System Error as "Adpative.." wonder how that got through!
Old Jul 8, 2019 | 05:01 AM
pauledddy's Avatar
Anyone have any insight as what to approach next?
Old Jul 8, 2019 | 07:18 AM
Cambo's Avatar
That would surprise me, but stranger things have happened.
The rear diff has it's own control module, it's a separate module to the suspension. But it could well be that you will get E-Diff Fault on the dash with the suspension module unplugged, have you tried unplugging the suspension module or not?
Surprises me that the resistor trick didn't work.
Old Jul 8, 2019 | 10:30 AM
pauledddy's Avatar
Unplugged the ADCM and true enough the E Diff warning light came on a long side the Adaptive warning light. Tried different resistors, ranged from 2.4 to 3.5 ohms. To no avail. Tried connecting the cables together to no avail. I'm stumped!
Old Jul 8, 2019 | 12:59 PM
pauledddy's Avatar
Tried using SDD to configure the ADCM but it needs to be online in order for that to work. So that's another option down!
Old Jul 17, 2020 | 05:09 AM
pauledddy's Avatar
Anyone have any ideas? Still can't find anything!
Old Jul 17, 2020 | 08:12 AM
jahummer's Avatar
Have you tried contacting Spires in Warwick? They offer after market coilover kits and and Matt was/is a suspension engineer at Jaguar. Also might have a try with Swallows Racing in Bristol As they have a lot of experience with the X150 in racing.
Old Jul 17, 2020 | 04:53 PM
George05's Avatar
Buy a helicopter lol
Old Jan 6, 2025 | 08:38 PM
resident_fng's Avatar
Going down this path now, did you ever find a solution?
Old Jan 7, 2025 | 01:25 AM
LJRXKR's Avatar
You may need to do some more searching but believe there is a big difference between CATS (4.2 XK) and the Adaptive (5.0 XK) suspension setup. The CATS is on/off and the Adaptive is a variable resistance to control level of damping. Which is probably why a resistor works with the 4.2 as it just tricks it to be on. Good luck.
Benson7
Mar 22, 2019 10:08 AM
harvest14
Oct 25, 2017 02:19 PM
Arqum Usmani
May 17, 2017 10:43 PM
Beavis
Jul 30, 2016 11:31 AM
Stuart@VelocityAP
Sep 23, 2015 02:13 PM
