CD player
Old Dec 25, 2020 | 06:46 AM
curlycat's Avatar
Default CD player
Finally got round to loading CD's into the magazine hoping for some of my choice music only to see:
checking disc... No disc loaded....
​​​same message for all six discs, yes they are the right way up! Just to be sure I put one in upside-down, same message. The player hasn't been used for some time.
Old Dec 25, 2020 | 07:17 AM
guy's Avatar
guy
Did you load cds or dvds? Single or Double sided? Also, not all modern digital music formats are supported.
Some claim that home burnt cds don’t work but I have never had a problem with iTunes.
Old Dec 25, 2020 | 07:37 AM
curlycat's Avatar
Default CD
Cd's, both burnt & original. The headset just says no CD loaded
Old Dec 25, 2020 | 07:44 AM
thierry_1500's Avatar
Could be a dirty lens, try using a cleaning disk:
https://www.walmart.com/ip/Maxell-CD...eaner/10135700
Old Dec 25, 2020 | 07:45 AM
Stuart S's Avatar
Ron,
You're in the wrong Forum. Your Public Profile shows that you have a 2002 XK8, which is an X100. This is the X150 Forum, for 2006-2014 aluminum XK/XKR models.
Nevertheless, this old thread should be helpful.
https://www.jaguarforums.com/forum/x...loading-17619/
Good Luck!
Stuart
P.S. And see the .pdf in Post #11 of this old thread for details on how to disassemble and align the gears:
https://www.jaguarforums.com/forum/x...no-disc-27536/
Old Dec 25, 2020 | 10:12 AM
curlycat's Avatar
Default CD
Thanks Stuart, didn't look properly when I posted on the forum I usual post on the XK8 XKR forum. I'll check out the link you sent. Ron
Old Dec 25, 2020 | 11:31 AM
tberg's Avatar
curlycat,
I've had this issue on my X100 XKR as well. Go to the trunk, pop out the cassette, put it back in making sure that it's pushed in hard and try it again. It should work after trying this a couple of times.
Old Dec 25, 2020 | 11:46 AM
curlycat's Avatar
Default CD
More thanks Stuart, followed the link, had it out cleaned & light oil moving parts, back in, top sounds. 😁🎶 thanks again.
Old Dec 25, 2020 | 12:58 PM
Stuart S's Avatar
That's what the button in the bottom right corner is for.
I'm glad you got it fixed!
Hawthorn
Sep 3, 2020 08:45 AM
Shoreguy
May 14, 2020 06:37 PM
Hawthorn
Nov 22, 2019 10:19 AM
walkman1
Dec 9, 2012 01:14 PM
