CEL - P0128 Disaster Averted
Old Feb 16, 2014 | 01:06 PM
TDub's Avatar
Default CEL - P0128 Disaster Averted
Check engine light came on the other day so I popped the thermostat out and could not believe what I saw......
Attached Thumbnails CEL - P0128 Disaster Averted-image-copy.jpeg   CEL - P0128 Disaster Averted-image-copy-3-.jpeg
Old Feb 16, 2014 | 01:23 PM
Ngarara's Avatar
Erk!
At least you get a warning these days, rather than suddenly seeing the temp gauge off the clock and steam from under the bonnet.
Old Feb 16, 2014 | 01:42 PM
hawaii's Avatar
Nice save!
Old Feb 17, 2014 | 12:29 AM
Any manufacturer name /code number on that Thermostat?
Old Feb 17, 2014 | 01:46 AM
TDub's Avatar
No manufacturer name but one piece is stamped with some numbers. I'll post a pic tomorrow. Calling dealer in the morning (12:30 am here &#128565 to get new one.
Have a sneaking feeling my recent original battery replacement may have something to do with it?? I am expecting some other little silly gremlins to start popping up. 😤
Old Feb 17, 2014 | 02:05 AM
There's a Part Number change on the 4.2 XKR at VIN B28435:
Yours looks to have broken up. The P/N change could be an "improved" design if Jaguar have had issues with the original.
Cost is £31.55 ($53) over here.
Old Feb 17, 2014 | 10:31 AM
amcdonal86's Avatar
That's exactly what happened on my '07 XKR.
Old Feb 17, 2014 | 10:48 AM
LstFord's Avatar
Default 2008 XKR Porfolio
I am wondering if this is something that just should be done as preventative maintenance? Is the thermostat accessible for those who don't do a lot of work on their cars?
Jim
Attached Thumbnails CEL - P0128 Disaster Averted-img_20131120_164703_122.jpg
Old Feb 17, 2014 | 05:01 PM
amcdonal86's Avatar
I don't think pieces would actually come off the thermostat and end up somewhere in the cooling system. The little rubber seal just sort of breaks up and dangles there, preventing the thermostat from closing properly.
The process of changing the thermostat on my XKR was pretty easy, requiring minimal hand tools. Basically remove the air intake tubing on the driver's side, then remove the coolant hose leading into the thermostat housing. That was probably the hardest part, but shouldn't be too difficult if you have a good set of locking pliers (which I did not have). Then there are 2 or 3 bolts holding the thermostat housing in. It comes off easily, and then you swap out the thermostat and the thermostat housing gasket, and put it all back together. Then you need to fill the coolant reservoir and then remove the supercharger fill plug (which requires a rather large hex socket) and replace the gasket/washer with a new one (order from dealer) and top that off too when the engine is warm.
Also one thing that was confusing reading the threads--the coolant outlet assembly on the XKR is made of aluminum and never needs to be replaced. On the XK it is plastic and should probably be replaced when replacing the thermostat.
Old Feb 17, 2014 | 05:04 PM
amcdonal86's Avatar
https://www.jaguarforums.com/forum/x...-change-99994/
Old Feb 17, 2014 | 05:12 PM
TDub's Avatar
Yep, just did mine today. Took about an hour tops and was not difficult at all. Had a bit of a scare when I fired her back up though. Message displayed "engine temperature indication" warning. Went away after a few minutes so I am guessing the coolant sensor was acting up or coolant was still flushing through the system.
Old Feb 17, 2014 | 05:19 PM
amcdonal86's Avatar
Interesting. Did you replace the supercharger fill plug washer?
Old Feb 17, 2014 | 07:28 PM
TDub's Avatar
Yes I did.
Old Feb 18, 2014 | 08:31 AM
Brutal's Avatar
Common and on the plastic housing non sc engines it is very advisable to replace the housing since they do break apart internally and crack externally as they age
Old Feb 18, 2014 | 04:53 PM
apost8n8's Avatar
Can an aluminum XKR replace the XK plastic one or are they different shapes? My 08 xk has small leaks at the manifold connections. I have had no warning but you can see the coolant leaks on the surrounding parts. The mechanic wanted ~$750 to replace it all but it sounds like it might be very simple even for someone not used to car work.
Old Feb 18, 2014 | 05:50 PM
Brutal's Avatar
No you cannot use a sc piece. Totally differant
Old Feb 19, 2014 | 11:40 PM
2007 Rick's Avatar
Default Thanks
Thanks for being on this forum !
bdboyle
Sep 16, 2019 05:58 PM
RSpi
Mar 21, 2016 12:02 PM
duecedriver
Dec 25, 2015 11:47 AM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
