Center air vent removal
Old Dec 21, 2019 | 06:21 AM
ChipnLong's Avatar
Default Center air vent removal
Any tips on removing the center dash air vent?
________________
2007 XK 4.2 (added by GGG)
Old Dec 21, 2019 | 06:53 AM
arenaej's Avatar
Here’s how I do it...
1. Move gear shift to “D” so there’s room to remove the entertainment center.
2. Cover the console with a towel to protect it.
3. Use a trim removal tool to remove the trim around the entertainment center.
4. Remove 6 torx screws that secure the entertainment center and slide it out.
5. Remove 2 torx screws holding the center vent.
Old Dec 21, 2019 | 06:58 AM
ChipnLong's Avatar
Thanks! I need to pull the audio any way to remove a POS FM transmitter installed by the PO.
Chip
Old Dec 21, 2019 | 07:02 AM
Here's a photo so you know what to expect:
Old Dec 21, 2019 | 08:35 AM
ChipnLong's Avatar
Thanks Graham. The louvers are white plastic painted black. Several of my louvers have almost no paint and looks poor. Bought a used OEM vent set to swap out louvers.
Old Dec 21, 2019 | 10:01 AM
RedRider48's Avatar
BTW, what year is your ride? Can be helpful for others having a similar request.
Old Dec 21, 2019 | 06:17 PM
ChipnLong's Avatar
2007 xk 4.2
Old Dec 21, 2019 | 06:38 PM
Sean W's Avatar
well try just the two smaller tori screws below the vent first once you remove the trim piece. I dunno about others, but I don't need to remove the other 6 bolts to pull out the center vent. So maybe the PO of my car did something backwards?
Old Dec 22, 2019 | 06:01 AM
According to the Workshop Manual, the Torx screws may not be fitted:
A useful exercise - I never knew the Vents are called Registers in Jaguar-speak.
Old Dec 22, 2019 | 07:37 AM
kj07xk's Avatar
Oh yeh, I’d forgotten about that term. Used it all the time while I was growing up to refer to the hot and cold air ‘registers’ in the house for the furnace. Thanks for that reminder!
Guillaume
Mar 23, 2025 06:26 AM
Hoosier XK8
May 22, 2017 04:04 PM
Chuck Schexnayder
Jan 29, 2017 01:18 PM
Coz
May 30, 2013 09:14 PM
gceckert
Apr 19, 2008 10:03 AM
