Code P0308
Old Jun 16, 2014 | 09:01 AM
07xkrUSA's Avatar
Default Code P0308
Does any body know anything about this code? Is it just a spark plug replacement or is it a vacuum leak? -- how can I find out?
Old Jun 16, 2014 | 09:42 AM
WhiteXKR's Avatar
Check the #8 spark plug well for water or oil contamination and replace the plug. If it is flooded with oil, the valve cover gasket needs to be replaced. If there is water in there, did you wash the engine?
If the problem still persists, the most likely cause is a failed coil.
It is not a vacuum leak with only this code.
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
Terry H
Jul 4, 2017 05:48 PM
JCam
Oct 23, 2016 08:27 PM
