Confirmation beep/chirp on double lock
Old Oct 22, 2015 | 05:06 PM
tommyd's Avatar
Default Confirmation beep/chirp on double lock
Hi,
I previously owned a US spec 2009 XKR PE and it did not generate a confirmation beep/chirp on double lock. I took it to the dealer and they told me that the sounder was bad and replaced the part. I now own a US spec 2010 XKR and it also does not beep/chirp on a double lock. Does anyone know if the XKR MY2010+ utilizes the sounder or horn for the confirmation on double lock? Does this need to be turned on in the software?
-Tom
Old Oct 22, 2015 | 07:00 PM
Stuart S's Avatar
The sounder in my 2009 XKR Portfolio went bad, too, and was replaced under warranty. It appears to be a common problem. I suspect it's the same in newer X150 models but don't know for sure.
Old Oct 22, 2015 | 07:18 PM
ralphwg's Avatar
I get a deeper tone with the double click on my 12 vert.
Old Oct 23, 2015 | 10:41 AM
tampamark's Avatar
On my 2012, I get no beep on first lock either by key or pressing the button on the handle. Should it beep, or can it be turned on? It does beep if I double tap the button or fob.
Old Oct 23, 2015 | 12:05 PM
Cee Jay's Avatar
I do and have always had the double-lock chirp on my 2010 XKR. I use it all the time. SUPPOSEDLY, it allows the electronics to go to sleep faster than the (I think) 15 minutes that it takes when not double-locked.
ELB3MD
Aug 12, 2024 05:41 AM
Geggen
Oct 27, 2015 01:30 AM
skadmiri1
Oct 25, 2015 01:06 PM
Rocky15
Oct 25, 2015 12:31 PM
DandyAndy
Oct 17, 2015 09:33 AM
