Coolant warning??
The outlet on my Jag's header tank broke off. Resulting in the coolant to leak out. I drove the car +/- 10km's before I saw steam emerging from under the bonnet. There was no warning what so ever!!
My S-Type had a warning light to warn you when the coolant was low.
I can't find any mention that the XK has any indicator of overheating or low coolant level!
Please help!!!!!
Please help!!!!!
The warning is limited to a FLUID LEVEL LOW warning in the MESSAGE CENTRE (see items boxed in red in the following extract from the Driver's Handbook):
This is probably because both the Temperature Gauge and the Low Coolant Level Sensor in the previous XK8/XKR and the XJ8/XJR were completely useless. By the time any warning appeared, the engine was already seriously overheated. Hopefully the XK/XKR warning is triggered more reliably.
Thanks Graham! My owners manual is a little different, but states the same. When my car lost the fluid, there was no indicator showing that she overheated.
Maybe I caught it just in time. It is horrifying to think that the engine must first overheat before you receive any kind of warning!
On my S-Type the header tank also leaked, but she had a sensor warning me that the fluid level was low. I replaced the tank with no further hassles.
I wonder if anyone else had problems with their header tanks, 2 of my 3 had tanks that perished?
Had low coolant in October and only got warning of "Engine Temperature Indication Fault" instead of Low Coolant.
Here was my Warning: https://www.jaguarforums.com/forum/x...86/#post608597
It looks like there are three temperature related warnings that could appear:
ENGINE TEMPERATURE HIGH:
Amber warning triangle illuminated in LCD at temperatures of between 118.0°C (244.4°F) and 119.3°C (246.8°F).
ENGINE OVERHEATING:
Red warning triangle illuminated in LCD at temperatures of 119.4°C (247°F) or above.
ENGINE TEMPERATURE INDICATION FAULT:
Red warning triangle illuminated LCD which means a fault has occurred in the engine management system and the engine temperature signal is no longer being received.
ENGINE OVERHEATING:
Provided the temperature at which these two warnings appear is accurate, that's a major improvement on the monitoring systems on previous models.
Where did you find the information?
From the X150 Factory Workshop Manual.....electrical section, comes the two attached jpgs concerning coolant overtemp.
I have never cared that much for warning lights. They never seem to give an early warning of pending doom.
There are several aftermarket gauges that plug into your OBDII port. I find that my '07 runs consistently at 203 degrees, which is exactly as Jaguar specifies.
203 degrees is a bit warm for my tastes. I know that under ideal circumstances like on a dyno, lab or race car the most power is made at higher coolant temperatures. Tuners like A. Graham Bell prefer a lower coolant/underhood temperature for street driving. I believe our OEM thermostat is a 190 degree model, which begins to open at 190 and is fully open at 203 degrees.
I know that Eurotoys offers a cooler thermostat: Jaguar Low-Temp Thermostat - Jaguar Performance Parts.
But this thermostat does not fit the 07+ XK/XKR. These use a much smaller size thermostat.
I'd like to exchange my OEM 190 degree thermostat. I know Jaguar does not offer a cooler model, but what cooler model will fit?
