Creaking Sound When Braking.
Old Feb 7, 2014 | 09:10 PM
bocatrip's Avatar
Default Creaking Sound When Braking.
Is it normal for the OEM brake pads to make the creaking noise when applying them at low speeds? I am planning on replacing them soon with ceramics due to the excessive dust and was hoping the creaking will be gone as well. My service advisor says the OEM pads do creak. Any feedback would be appreciated.
Old Feb 7, 2014 | 09:22 PM
amcdonal86's Avatar
Yes, it's normal. But there is a TSB out for it where you apply a special grease to specific parts of the pads/calipers to prevent the noise.
Old Feb 8, 2014 | 06:37 AM
sjtyrer's Avatar
Yes it is a common issue. I had it on my 2007 XK until I renewed the pads all round with the Akebono ceramics. Greased up the caliper/pad contact points thoroughly using regular brake grease, tightened everything up and all is good. To be honest I did nothing special or use any special grease. A little TLC was all that was needed.
Steve
Old Feb 8, 2014 | 07:26 AM
Lothar52's Avatar
My brakes creak like crazy... I was told that high performance break creak like crazy?! It made me feel better about it...
Old Feb 8, 2014 | 07:28 AM
Lothar52's Avatar
Aftermarket ceramic brakes for the XKR and XKRS? Where does one buy this?!?!?
Old Feb 8, 2014 | 10:13 AM
bocatrip's Avatar
Steve
Glad to hear that the ceramics helped eliminate the creaking. Akebonos are not available for my fronts so I am going for Centric Posi Quiet Ceramics all around. I haven't bothered with the TSB hoping that just changing the pads would be the remedy.
Old Feb 9, 2014 | 11:34 AM
Lothar52's Avatar
Wait a mintues, where is it that we can purchase aftermarket Carbon Ceramic Brakes like the XKR-S GT has???
Old Feb 9, 2014 | 11:42 AM
bocatrip's Avatar
It was difficult enough finding Ceramics for fronts and rears on my 2010 XK which I found out is different than the 07-09 XKs. I'm not sure of availability for the limited production models. I have a feeling it might be a task to find them.
boiler
US Southwest
Dec 20, 2025 12:38 AM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
Rocky15
Sep 28, 2015 04:59 PM
Long Islander
Sep 27, 2015 03:45 PM
