CTEK 3300 question
Old Feb 10, 2014 | 07:18 AM
chazaroo's Avatar
Default CTEK 3300 question
Here in this part of FL, power surges are common...very common. I'm concerned that a surge could not only damage the charger but the car as well. Is that something I should be worried about?
Old Feb 10, 2014 | 07:39 AM
Schwabe's Avatar
I would check the CTEK homepage for that. But I can tell you that the CTEK connectors have fuses in them which should prevent transmitting any surges to the car.
The car charger itself provides and even charge during the charging and float stage and a pulse during conditioning stage. It should not be capable of transmitting a charge large than those. It is a transformer converting 110 into 12 volt.
But as I mentioned first I would check the FAQ on the CTEK page for more information.
WhiteXKR's Avatar
I suspect a major surge would damage the charger long before before it damages the car, but the answer to your question really depends on the proprietary design details of the charger. You can always see what CTEK says about it.
If you have concerns and want to play it as safe as possible, plug the charger into a quality computer surge suppressor.
redgear
Sep 18, 2015 10:05 AM
SeanU
Sep 18, 2015 08:09 AM
kamiar
Sep 17, 2015 06:30 PM
pnwrs2000
Sep 17, 2015 04:04 PM
DustysSon
Sep 13, 2015 04:17 AM
