This dam squeak is driving me crazy!! - RESOLVED
Old Jun 8, 2020 | 08:49 AM
Added "RESOLVED" to your thread title so it stands out in searches when the next owner comes along looking for possible causes.
Old Jun 11, 2020 | 10:02 AM
gkubrak's Avatar
Bad news, the noise is back. This time on the left side, not the right. Still very loud.
Idk how this is possible. I replaced the bushings and the upper arms on BOTH sides, yet the noise moved from right to left.
I'm just about ready to drive this car off a cliff... with me in it.
Guess it's back to the jackstands ...
Old Aug 12, 2020 | 05:47 PM
gkubrak's Avatar
Ok I finally got it.
The noise is coming from the LH lower control arm bushing. The rear, inside one. I put the car on ramps and started spraying each bushing 1 by 1, and pushing down on the trunk after every spray. The noise completely went away after I sprayed that bushing. Visually, it clearly needs to be replaced. Thought the upper ones were bad, lower ones were worse.
So its on to replacing the lower arms. At least I won't have to disconnect the brake lines again.
Old Aug 12, 2020 | 05:53 PM
George05's Avatar
Good news
Old Aug 17, 2020 | 01:52 PM
gkubrak's Avatar
FYI the lower control arm from rockauto (DORMAN) did not fit. The outer bushing was too long. Should be 54mm but theirs was 60mm. I sent them back and hopefully the other brand they send does fit.
Left one came out ok but the right one, well ...
Had to cut out a nice piece of frame for the bolt to clear ...
Old Oct 14, 2020 | 12:58 PM
dirtyodwyer's Avatar
Hey gkubrak, do you know the part number on the lower control arm you purchased on Rock Auto and do you know if there is a part number from Ford that works? I've seen that the Lincoln LS from 2006 has some of the same parts as the Jaguar S and the XK too. I have a 2007 XK and not sure if it has the same parts as your XKR or if the Ford/Lincoln parts would work.
I'm getting ready to order all my suspension parts like the wishbone, sway bar, tie rods etc. It would be nice to see a cross reference where we can punch in the Jaguar part number and see the corresponding Ford Part number. Is that available anywhere?
Old Oct 15, 2020 | 09:19 AM
gkubrak's Avatar
Check this thread out:
https://www.jaguarforums.com/forum/x...l-arms-187168/
I only know of the upper rear arms from Ford. The cross reference list you mention is a unicorn - but yes it would be nice.
I bought all MOVOTEC brand from Rock Auto + the rear upper arms from Ford. However I returned the front lower arms because they were still in good shape and a pain to change out.
MisplacedPriorities
Sep 10, 2019 11:42 AM
iownme
Apr 1, 2016 05:20 AM
jagbuff
46
Apr 20, 2013 05:48 AM
hk55874
Jan 19, 2010 01:43 AM
bigdaddywuff
Nov 17, 2008 08:35 AM
