Dashcam Power Location
Old Jan 2, 2022 | 11:19 AM
tcsamir21's Avatar
Default Dashcam Power Location
Hi! Is it possible to use this accessory socket for a Dashcam on the 2010 XKR 5.0? Because i don‘t want to damage anything. Does it also record if the engine is not running ? Because it says it will discharge the battery..
Thanks !
Old Jan 2, 2022 | 07:18 PM
JackJohn's Avatar
The power outlet in the glove box as well as the one in the ash tray are both powered off when the ignition is turned off.
Old Jan 3, 2022 | 05:17 AM
tcsamir21's Avatar
thanks!
Do you know if i can i use this outlet or could it damage something after long usage?
Old Jan 3, 2022 | 06:25 AM
guy's Avatar
guy
I think as long as you stick to a device rated for 12v DC and a draw of less than 10 A, what could be the issue?
Old Jan 3, 2022 | 05:20 PM
u102768's Avatar
The sockets actually stay live for a bit while the car is in convenience mode but will power off eventually. They power off immediately if you lock the car though.
Old Jan 4, 2022 | 09:12 AM
fxdwg's Avatar
I'd modify what's been said slightly, as I see a slightly different set of happenings on my 07 XKR.
The 12V point in the ashtray does stay live for some period of time after turning the ignition off. I've never watched it to see how long it stays active, but it does stay active. My ADU is plugged in there and does stay running after the car is shut off. I usually pull the usb adapter to shut it down.
The glovebox 12V point operates differently. It DOES shut off as the ignition is turned off (and start up with the ignition being turned on). I have a radar detector plugged in that point and it goes on and off with the ignition.
Since the OP has an 07, this may give a more accurate set of happenings for his car.
XKRfangs
Apr 4, 2021 09:53 PM
AlexKeyWest
Nov 18, 2018 08:51 AM
Jag4
Sep 9, 2018 07:54 PM
Busa
General Tech Help
Sep 29, 2017 09:50 AM
Black Panther
Dec 30, 2010 06:25 AM
