Daylight Driving Lights
Old Aug 14, 2018 | 06:16 AM
Ter11's Avatar
Default Daylight Driving Lights
hi all
I have a question about the logic behind the Daylight driving lights logic that was installed in XK up and including until 2011 (after 2011 the faceliftes XKs obtained proper day driving lights, ie. specific lights for day use).
Until 2011 the XK does use the normal beam headlights as day driving lights. Due to legislation in my country my 2011 XK has the normal beam headlights on when the engine runs, even if the lights switch is “off”. My car also has the infamous AFS or what ever the name is: the lights that dynamicly follow the road.
Because in my car the normal beam lights are on even if stalk switch is off, what is the difference whether I have the switch off, normal beam head lights or on Auto? The head light are on in all these three switch positions. Does it make a difference for the AFS?
best
ter
Old Aug 14, 2018 | 07:08 AM
TexasTraveler's Avatar
DRL’s are only the headlights, I believe the difference in auto and off would be that your tail lights would automatically come on in auto...
Old Aug 14, 2018 | 08:46 AM
Ter11's Avatar
thanks. Good point. I just went to the garage to check. The tail lights are on even when stalk “off”. I still need to check when driving, but I believe that on “off” the AFS is not active. It is only when normal bean on or Auto. Btw - same thing for the rain sensor for the wipers: only active when the lights are on Auto, right? I tested it today and the wipers seem to be strictly time triggered when on intermittent and light not on auto, which I find good, because often the sensor wipers are not doing exactly as Iike.
Br
ter
Old Aug 14, 2018 | 09:34 AM
Br
ter
Where are you located? I believe you are correct when off is selected the AFS is not active... Yes, if in auto and you turn wipers on your lights turn on, also there is a speed dependent mode which turns your wipers to lowest setting when stopped and once you start moving again the wipers go back to original speed.
Old Aug 14, 2018 | 10:03 AM
Ter11's Avatar
I am located in Switzerland
Old Aug 14, 2018 | 10:14 AM
I wonder if one of the differences in Canadian, Scandinavian or Polish DRL option is the tail lights... You say that your tail lights are on during the day? I will have to confirm but when I turned my DRL on I chose the Canadian option and I don't believe my tail lights are on during the day...
Old Aug 14, 2018 | 11:30 AM
Ter11's Avatar
I am not sure which DRL option I have active (was activated before I bought the vehicle), but i guess it is most probably the Scandinavian/European one.
Old Aug 14, 2018 | 05:59 PM
sov211's Avatar
That is not correct. In markets (such as Canada) which require DRL , Jaguars have ALL exterior lights illuminated, front, side and rear regardless of the position of the lighting control (unlike other makes which often have only the front lights on). So in a Jaguar it is not necessary to touch the light switch; it can be left in the OFF position, with one caveat: in Jaguars built for 2005 and later, the dash lights are not illuminated with the DRL system (and therefore at night the switch must be turned on). But Jaguars built before 2005 have all lights, including dash lights, on all the time. My wife has been driving her X-Type for 15 years, day and night, and the light switch has been in the OFF position all that time - never touched. On my 2005 X-Type wagon I only have to touch the light switch when I need to illuminate the dash instruments. All these cars have AUTO lighting systems but that is redundant in DRL markets.
Old Aug 14, 2018 | 06:22 PM
Cee Jay's Avatar
JLR SDD may have something to say on this subject....................
Old Aug 14, 2018 | 06:57 PM
i should have been more clear, I was referring to the AFS that OP referenced. Please correct me if I am wrong, but I thought I read somewhere that when DRL’s are on the AFS is not working... I will have to get someone to check and see if my tail lights come on with DRL as you mentioned, since I did chose the Canadian option.
Old Aug 14, 2018 | 07:00 PM
I should have been more clear, I was referring to the AFS that OP referenced. Please correct me if I am wrong, but I thought I read somewhere that when DRL’s are on the AFS is not working...
edit: so I did confirm that the Canadian DRL option turns on all lights including rear. I also confirmed that if you leave your stalk in off position the AFS is not activated. So if you want AFS, stalk has to be on or auto.
Old Aug 14, 2018 | 07:31 PM
ralphwg's Avatar
I think the OP is asking if it is necessary to turn the lights on to get the full effect of the entire lighting system if the DRLs are on during the daytime. I that the answer to the question is to put the light switch in the stalk to automatic and you will get the best of both worlds. The DRLs will work in daylight (no interior lighting). And when the lights get turned on automatically at dusk the interior lights will automatically light up along with the green Icon on the lower right of the panel in front of the driver.
Old Aug 14, 2018 | 07:49 PM
Originally Posted by ralphwg
I think the OP is asking if it necessary to turn the lights on to get the full effect of the entire lighting system if the DRLs are on during the daytime. I think that the answer to the question is to put the light switch in the stalk to automatic and you will get the best of both worlds. The DLRs will work in daylight (no ior lighting). And when the lights get turned on automatically at dusk the interior lights will automatically light up along with the green Icon on the lower right of the panel in front of the driver.
Agreed, that’s how I use mine...
Old Aug 15, 2018 | 01:43 AM
Ter11's Avatar
Dear all! Thanks for shedding light onto this subject. All clear now. I was interested in this amongst other to find out if AFS can be deactivated in some way. Reason: to only use it when needed ie. not in daytime- to reduce wear&tear on the AFS mechanisms, as failure here can result in very costly light replacement.
Br
ter
Old Aug 15, 2018 | 06:46 AM
Patrick Wong's Avatar
My 2007 is a pre-production model and has DRL activated. As sov211 indicated, all exterior lights are on when the gear selector is moved to D regardless of the light switch position. I have to use the light switch at night so that the interior instrument lighting turns on. I don't like the way that DRL is implemented and would prefer for that to be deactivated. However I am afraid to use my bootleg SDD as that will probably screw up some obscure configuration file...
Old Aug 16, 2018 | 04:19 AM
Ter11's Avatar
While the workmanual confirms that Canadian DRL does deactivate AFS in off mode, it is silent to this for European DRL.
For my car I can confirm that AFS becomes active even in off mode. Unfortunately. But it seems it does so only when dark outside. Not 100% sure, but this is what I experienced driving around yesterday in my XK 2011.
br
ter
tommyzr
Oct 26, 2015 07:41 PM
fljag
May 10, 2015 04:16 PM
mikew43
Mexico, South America
Nov 21, 2012 09:25 AM
exexpat
Apr 28, 2010 03:11 PM
jaguser
Jul 9, 2009 06:56 PM
