Diff rebuild Gen 2
Old Nov 4, 2025 | 03:50 AM
steve_k_xk's Avatar
Default Diff rebuild Gen 2
Currently rebuilding my gen 2 differential xk 2007-2009 looking for parts numbers for all the bearings/seal (carrier and both pinon bearings) also the crush washer & snap ring whilst im at it
Can anyone help with this ??
Old Nov 4, 2025 | 06:01 AM
guy's Avatar
guy
Subscribed.
Interesting... I have the Gen 1, And it doesn't need rebuilding... yet. I have been changing the fluid every 60K kms. Fingers crossed. Best of luck!
Old Nov 4, 2025 | 07:15 AM
kj07xk's Avatar
How does one know if they have a Gen 1 or Gen 2 diff?
I seem to recall someone rebuilding a diff here, maybe it was @Ranchero50 in his ‘Green Turtle…’ thread?
Old Nov 4, 2025 | 01:53 PM
steve_k_xk's Avatar
If you have a 4.2l regardless of it being R or n/a and in the x150 chassis/range it's definitely a gen2.
They were also fitted to
Xf , xj , s-type however to my knowledge no 4.0 ever came gen 2 (they were gen 1) only the 4.2's & 3.9's from Thunderbird & 03-06 Lincoln Ls received them.
Old Nov 5, 2025 | 06:34 AM
guy's Avatar
guy
FYI...
I have the Gen 1.
Incidentally, you may find the part numbers you are looking for in this thread: https://www.jaguarforums.com/forum/x...arings-102296/
Old Nov 6, 2025 | 12:20 AM
steve_k_xk's Avatar
Thanks Jeff!
Old Nov 18, 2025 | 01:16 AM
steve_k_xk's Avatar
Differential stripped and components cleaned just waiting on seals & bearings to arrive from the U S
Old Jan 31, 2026 | 02:42 AM
steve_k_xk's Avatar
Finally got around to putting this back together - pinon peload set on the new bearings
Just have carrier bearing cap to torque down - can someone help me out on torque specs normally it's around 100nm but I can't find anything
Old Jan 31, 2026 | 08:22 AM
guy's Avatar
guy
i know, i know...
But there are torque specs listed here:
https://www.diyford.com/ford-9-inch-...mber-assembly/
and here:
https://performanceparts.ford.com/do...htM-4209-8.pdf
Old Jan 31, 2026 | 01:49 PM
steve_k_xk's Avatar
I just checked the links they're for a completely differential (although in their specific application they went 80ft lbs/ 108nm on bearing carrier caps)
Old Jan 31, 2026 | 06:40 PM
guy's Avatar
guy
sorry Steve, meant to take the readings from the FoMoCo 8" Racing differential, which ours is derived.
You probably noticed that in our workshop manual, not all the torques are provided.
File Type: pdf
Old Jan 31, 2026 | 07:20 PM
steve_k_xk's Avatar
I saw that , I think I'll simply torque it down to 100nm run some loctite and call it a day ..done
Old Feb 1, 2026 | 06:55 AM
guy's Avatar
guy
btw, nice job! Surprised you didn't drop the Quaife in there while it was apart.
Old Feb 2, 2026 | 02:45 AM
steve_k_xk's Avatar
Things are looking good oil seals installed for the CV shafts, carrier bearing cap torqued down and retaining circlip also installed just have the rear cover to go .
Yeah I was thinking i'll see how the new ratio (3.58) comes along then decide on which diff I'll put a quaife in .
* Note on setting pinon preload
Once the play is completely out of the pinnon work the pinnon nut in small increments , then measure the drag be very cautious as pinnon preload comes around extremely quickly stick to your "1/8 of a turn" procedure
Old Feb 2, 2026 | 06:28 AM
guy's Avatar
guy
How much would shipping my diff to AU set me back ;-)
Old Feb 2, 2026 | 01:57 PM
steve_k_xk's Avatar
Let me try and get a posi in one of them first I have another spare diff here I'm going to strip down
Old Feb 21, 2026 | 10:36 PM
steve_k_xk's Avatar
Rebuilt 3.58 diff finally swapped out today (the OEM diff was caked up looking very nasty) ..everything seems to be good filled it up with 80-140 and looking to run it in over the next 2 weeks
Old Feb 22, 2026 | 07:47 AM
guy's Avatar
guy
Nicely done!
Addicted2boost
Sep 30, 2023 08:31 AM
JustNiz
Jan 4, 2023 11:48 AM
adam_quantrill
May 14, 2018 04:12 PM
nasa25
Nov 17, 2016 06:24 PM
Daim
May 17, 2015 05:49 PM
