DIY oil change on 2011 XKR
Old Oct 8, 2015 | 03:58 PM
vacolorito's Avatar
Default DIY oil change on 2011 XKR
Anyone have experience in changing the oil yourself on a 2011 XKR? My local dealer wants $200 for an oil change. I am somewhat handy, have changed oil on other vehicles, but not on a car of this type.
Any advice is appreciated.
Old Oct 8, 2015 | 04:51 PM
Cee Jay's Avatar
You'll need a vacuum pump, as the oil is removed through the oil filler cap tube. If you don't have a pump handy, you'll have to pay to get it done. $200 is quite ridiculous though. I pay $86 for full synthetic and a Wix filter at a local European Vehicle Specialist place. Of course, they don't do everything a Jaguar dealer would do, but most of it. I do the rest. My closest Jag dealer is well over an hour away.
Old Oct 8, 2015 | 09:31 PM
axr6's Avatar
Many people have used the conventional drain plug in the oil pan to change the oil. Since the Oil filter is located on top of the engine I find it easier to use a 12V electric pump that I got on Amazon for about $27. It pulls the hot oil out faster than I could lift the car. I did have to get a short clear plastic tubing from Hope Depot to fit the car's suction tube.
Old Aug 3, 2016 | 10:17 AM
Stevenwhitney's Avatar
Albert. Where is the oil filter located on the 2012 XJL portfolio?
Old Aug 3, 2016 | 09:48 PM
White Bear's Avatar
I use one of these, you can order one on line from Snap On for a little over $120.00, or go to Harbor Freight and see if they have something equivalent, no doubt that'll be cheaper but no saying how long it'll last.
Regards,
Old Aug 3, 2016 | 10:34 PM
Cee Jay's Avatar
I ordered a 12 Volt oil-specific pump from Amazon for I think $29. It works great, but the leads on it are worthless with the battery in the boot. I use a spare battery I have lying around to run it. Just have to make sure the oil is somewhere near operating temperature and not a cold sludge or it will work the motor too hard.
Leeper's Avatar
Banned
http://www.tooldiscounter.com/ItemDisplay.cfm?lookup=MIT7201&source=froogle&kw=M IT7201&gclid=CjwKEAjwrIa9BRD5_dvqqazMrFESJACdv27G4 LClCnknAhlDSCKVpad5vyuMB52YEUCWEmV-THLSjRoCQ2nw_wcB
Old Aug 3, 2016 | 11:32 PM
White Bear's Avatar
Yes Leeper, that's the one, better price than I paid too!
I use it on my Audi's, all the Jags, even used it on the Cessna once!
Makes changing oil so much quicker and less messy.
Great tool.
Regards,
Ozzy_UK
General Tech Help
Jan 14, 2016 02:52 PM
jerry_hoback
US Midwest
Sep 27, 2015 05:38 PM
SeanU
Sep 26, 2015 07:01 AM
Tim Goz
Sep 17, 2015 09:11 AM
drewlabarbera
Sep 14, 2015 07:46 PM
