Do your rear nuts stick out
Old Mar 31, 2017 | 03:06 PM
jagtoes's Avatar
Default Do your rear nuts stick out
OK so I was just cleaning up a bit and noticed when I cleaned my rear wheels (Nevis 20") that the lug nuts stuck out. So I didn't notice it when I cleaned the fronts and went back to check. Sure enough the rear lug nuts do not go in as far as the fronts so they are above the face of the wheel. The front ones are flush so I guessing that the off set has something to do with the depth of the counter-bore . Is this the same for the other wheel styles and sizes. Just a general question.
Old Mar 31, 2017 | 03:37 PM
tampamark's Avatar
Sounds like you have a very impressive set of nuts. Mine are not different from back to front in my 2012 with 19" rims. Deez nuts are the same.
Old Mar 31, 2017 | 05:31 PM
jagtoes's Avatar
You know what they say about guys with little wheels .
Old Mar 31, 2017 | 05:56 PM
tampamark's Avatar
Ha, yes, built for comfort. Ride that is...
Old Mar 31, 2017 | 07:00 PM
richzak's Avatar
Jagtoes:
On my 2009 Jaguar XKR, the wheels (both Front & Rear) were fitted with OEM Jaguar lug nuts. Both the front and rear wheel lug nuts were recessed into the wheel. Thus all wheels had the same depth.
I have seen wheels, where the front and rear lugs have stuck out past the wheel lug, drilled holes. This is quite prevalent when using Spline Lug Nuts commonly found on "tuner" type cars.
I would suggest that you pull a lug nut from the front wheel that appears recessed. There is a possibility the rear lug nuts are actually longer in size than the front lug nuts.
As you already know, size does matter, especially when it comes to length.
Other than this, I would have no other explanation of why there would be a difference between the front and rear.
Although you do not have Spline Lug Nuts on the Jaguar, I have attached a few images that compare a short vs. long lug nut.
Click the image to enlarge.
Attached Thumbnails Do your rear nuts stick out-spline-lug-nuts-short.jpg   Do your rear nuts stick out-spline-lug-nuts-long.jpg
Old Mar 31, 2017 | 08:20 PM
jagtoes's Avatar
Originally Posted by richzak
Jagtoes:
They are all the same size and are OEM cap type lug nuts. Next week I'll be pulling the rears for their annual clean and polish and I'll measure the depth of the counter bore. Both rears stick out the same amount and both fronts are flush with the wheel. Being staggered the rears are wider and the off set is different from the fronts.
Old Mar 31, 2017 | 09:24 PM
Cee Jay's Avatar
I also have 20" Nevis wheels. The Front nuts do indeed sit below the wheel surface while the rears are above. Aftermarket nuts, but about the same size as stock.
Old Mar 31, 2017 | 11:34 PM
richzak's Avatar
My 2009 XKR was all 20" wheels all around (Jag OEM Selena Wheels).
Old Apr 1, 2017 | 06:49 AM
JagV8's Avatar
I wouldn't want my nuts to stick out...
Old Apr 1, 2017 | 10:52 AM
tampamark's Avatar
If they are going to stick out might as well make them into a Mad-Max weapon and get some spike lug nuts that REALLY stick out.
Old Apr 1, 2017 | 01:48 PM
Sean W's Avatar
The thread titled asked "Do your rear nuts stick out". I only have one set and their usually in front, but yes if I run really fast in jogging shorts....
Old Apr 1, 2017 | 02:30 PM
jagtoes's Avatar
You'll find as you get older they will be in the rear. TMI
Old Apr 1, 2017 | 03:49 PM
Ranchero50's Avatar
You forgot the disclaimer that it only happens when the wife allows you out with them so you can enjoy the car.
Old Apr 1, 2017 | 06:30 PM
ralphwg's Avatar
I can't stop laughing. well done gentlemen!!!
