Drivers side door rattle-vibration
Old Nov 9, 2018 | 03:34 PM
jpk112's Avatar
Default Drivers side door rattle-vibration
Hello:So, I have noticed that at certain speeds on rough roads I hear a vibrating noise coming from my driver’s door. The noise reminds me of a screw vibrating on a metal plate if that makes any sense? Any suggestions on what this noise could caused by? Or any suggestion on an excellent dealer in Norther California that has the technicians that have solved rattle and or sound issues in the past that you would recommend. My local dealer has tried once to solve the issue so I am willing to try something new even if it means going out of town to have the car worked on.
Thanks in advance.
John
2013 XK Coupe
Old Nov 10, 2018 | 01:35 PM
Rick7311's Avatar
Default Have u taken the panel off
I would think if you took the door panel off & drove the car it would be fairly easy to determine where the sound is coming from. I’ve had my panels off due to some locals that thought it would be fun going down the block & shattering people’s windows. I did the glass replacement on both doors & it’s a fairly simple process. My first thought is the cable that goes from the inner door handle to the licking mechanism. It is wrapped in foam but can rattle if isn’t set in its proper position. I’m in the Bay Area, I’d be happy to help out if I can. Send me a pm.
Old Nov 10, 2018 | 02:11 PM
Rick7311's Avatar
Default Another thought
If you’re close enough I’d be happy to take a look for you.
Old Nov 13, 2018 | 11:41 AM
jpk112's Avatar
Thank you for the suggestions on what might be causing my car's door rattle. I will be bringing up the cable for the locking mechanism when I bring my car in for service this month. I have decided to give my local dealership one more chance to rectify this problem.
Once again thank you so much for the response, it is really appreciated.
John
2013 XK Coupe
Old Nov 13, 2018 | 01:17 PM
110reef's Avatar
Probably not the issue, but I find that if my seat is back too far that it will make a noise as it hits the panel behind the seat from time to time.
Old Jan 10, 2019 | 11:26 AM
jpk112's Avatar
Update. I took my car in for service and had the technician drive with me to hear my door rattle. Luckily the door rattle appeared within a block and the technician heard it. So it turned out to be the Regulator cable in the door which had come unclipped and was repaired. The rattle is 90% gone and only appears on the roughest roads when cold at only OCD levels. On Christmas day I took a ride over the same route that originally alerted me to the rattle it was gone on. What a great Christmas present. Once again thanks for the replies, so grateful to be a part of this community.
File Type: pdf
Old Jan 10, 2019 | 11:50 AM
TexasTraveler's Avatar
And that the dealer didn't charge you makes it even better... Great customer service!!!
Old Jan 10, 2019 | 09:13 PM
carealtor's Avatar
That's my dealership too. They have always treated me very well there.
wolfpck1
Feb 21, 2021 09:49 PM
mfennell
Jul 30, 2019 10:43 AM
GordoCatCar
Oct 17, 2017 09:20 PM
stremsjg
Jan 15, 2012 02:24 PM
aluni2230
Dec 12, 2011 02:13 PM
