Elite RR exhaust noise
Old Aug 11, 2015 | 03:09 AM
8bit's Avatar
Received and fitted mine yesterday. Sounds great. I wouldn't have described the volume as "brutal" personally but my car doesn't have the upgraded pulley and remap. The tone of the sound is excellent though, very purposeful. It is louder when on a charge but at normal driving it's still possible to be civilised. Exactly what I was looking for.
Looks the part too, I'll upload some photos later.
Old Aug 11, 2015 | 03:51 AM
powerhouse's Avatar
Glad to hear your happy with it, have you one center box or still the two fitted.
Cannonball Ireland is on the 11 th of next month which i'm doing, did it last year, 3 great days of good driving and night fun. If you would like to do it or any other member out there, details are on the link, some awesome machines entered,
http://cannonball.ie/
Old Aug 11, 2015 | 06:37 AM
8bit's Avatar
No center boxes at all, the Spires middle pipes only have a X-pipe just behind the transmission and that's it, just straight pipes to the back box. I was worried it might be too loud like that but so far it seems fine, in as much as it's still possible to stay fairly quiet when I want to but there's plenty of noise available when hoofing it
Thanks for the link, I won't make that one though, heading to the 'ring at the end of September
Old Aug 11, 2015 | 07:19 AM
powerhouse's Avatar
Nice one that should be good.
Old Aug 11, 2015 | 05:25 PM
8bit's Avatar
Got some clips of mine. This is it on first start last night:
And this is it under some revs tonight:
Old Aug 11, 2015 | 05:57 PM
powerhouse's Avatar
Good job, sounds nice, a bit tamer than mine, but that could be tuning and that i have a different center box set up, windows down all the time now, who needs a radio when you have music like that.
Old Aug 11, 2015 | 06:48 PM
ralphwg's Avatar
Sounds great!!
Old Aug 11, 2015 | 10:14 PM
  #28
RedRider48's Avatar
That sounds like a big cat growling.......
Old Aug 12, 2015 | 04:25 AM
8bit's Avatar
Thanks guys, very pleased with it
I'd have thought if it was just down to the center section then mine would probably be louder as I have no center silencers at all. I can only assume that your pulley and ECU map make it louder (more boost so bigger bangs in the cylinders) and perhaps the pipe on the Elite center section is wider; the pipe on my back section is wider than that on my Spires middle.
I actually find it much louder with the windows up, unless I'm driving in between hard walls etc. The snarl on cold start in my garage is the exact opposite of tame
Old Aug 12, 2015 | 06:04 AM
  #30
powerhouse's Avatar
The growl is exactly as a jag should be , sounds like the cat. Mine has full 3" pipes to the cats, which i thinks makes a difference. As it wears in a bit i would say it will even get louder. Put your car in the S mode and take it for a spin and see is there any difference in noise, should even go up a bit with higher revs.
Old Aug 12, 2015 | 08:42 AM
  #31
8bit's Avatar
Already done that, in S at full pelt it's definitely not shy
Old Aug 12, 2015 | 06:07 PM
  #32
powerhouse's Avatar
Have you a decibel reader app on you phone or maybe you can get the app, get some one to hold it behind the car and see what idle reads and then a blast of throttle, see what readings give you.
Old Aug 13, 2015 | 07:39 AM
  #33
8bit's Avatar
Yeah I'll need to do that anyway to make sure it doesn't exceed the noise limit for the 'ring. If it does then the stock box will have to go back on for the trip. I've got an app, I'll post back here with results. Do you know what yours reads?
Old Aug 13, 2015 | 01:10 PM
  #34
powerhouse's Avatar
Did it today, at idle it's around the 74 db and with a quick bust of throttle it reached 128 db, brutal high pitch . In Ireland you can't pass 90 db for the car test. They don't really have an issue but some boy racers with sports back boxes are asked to remove them. The examiner really didn't bat an eyelid about the noise. At the end of the test he commented on how lovely it sounded. Sounded lovely in the confined space of the test center.
Poet
Feb 7, 2025 02:18 PM
silkcat
Jan 18, 2025 04:29 AM
revauto
Sep 17, 2020 03:50 PM
JimC64
31
May 30, 2016 03:04 PM
Woznaldo
Sep 26, 2015 11:02 AM
