Engine sounds. 4.2L XKR
Old Aug 30, 2025 | 03:47 PM
Circumnavigator's Avatar
Default Engine sounds. 4.2L XKR
Thought I’d record a cold start and after warm up (idle drops).
As a new XKR owner, have no idea what is a good sound or a bad sound.
Few things.
— Right at start and at the point where the idle drops, the car shakes. Pretty hard for a second or two.
Is that due to the engine/trans mounts needing replacement?
— As the idle drops, there is a loud click. I think you can hear it in the first video. Guessing something is engaging or a sensor turns something on.
You guys hear anything of concern?Cold start:
Engine warm:
Thanks as always!
Old Aug 30, 2025 | 09:42 PM
LJRXKR's Avatar
Generally hard to tell through video as the mic does make some noises louder than in real life. But the car sounds fine to me. Most of that noise is just usual engine stuff. You could check the engine mounts and see if there's any leakage/misting as I believe they're fluid filled. But if they're that far gone you'd likely notice knocking when you go on/off throttle quickly.
Old Aug 30, 2025 | 09:55 PM
Yes sir. In the PPI when I bought it recently, the engine and trans mounts were starting to leak a bit.
On the list of first things to have done.
Old Aug 31, 2025 | 06:50 AM
guy's Avatar
guy
Is that a worn idler pulley I hear as well?
You will learn that she likes clean oil, filled to spec. Wander away from that and she gets “tickety” and “rough”.
Clean air filters make a huge difference.
As does a well cleaned and sealed throttle body.
When she starts to be thirsty on the oil, change the PCV valve.
Old Aug 31, 2025 | 08:50 AM
Stuart S's Avatar
Do you have the Engine Appearance Cover? It helps reduce engine noises a bit.
When I get home from a drive and am parked in my garage, I always open the hood (bonnet) to let the heat escape to prolong the longevity of the rubber parts in the engine compartment. I also check the fluid levels in the clear reservoirs to see if there are signs of any leaks.
Old Aug 31, 2025 | 09:29 AM
Yes sir. You and I compared styles, I have all three hydro dipped, but you have the killer red stencil and leaper sticker.
At least for now, before bed and in the morning I’m checking all accessible levels. And the bonnet stays open most of the time as a reminder before I take her out. Mostly monitoring the the coolant situation which only leaks under pressure from that silly hose/nipple. But also building a habit, kind of like making the bed.
Old Aug 31, 2025 | 10:02 AM
Ugh, hope not that sounds expensive. Or at least tedious. AI tells me it’s a simple 1hr job for a pro and $100 for parts. No idea.
Yeah, she is in oil limbo with a couple of faux pas.
for some random reason, she was 2-3 quarts down when I had her inspected. The guys messed up and overfilled her (3/8” above full line on stick) and put in 5w20 instead of 5w30. Which of course just splits the difference. So she has basically 5w24 lol.
Been a week building my tools and equipment. Jack, stands, torque wrenches arrive today, etc.
Then I will do a full drain/filter/refill.
As soon as my “soft coated 19m” socket and torque wrench gets here today, I’ll take a peek at the air filters. Need to remove a few screws in the wells anyway to drop the under cover in the front.
Ok, oil hasn’t dropped since she was slightly overfilled. So no worries there yet. Thank goodness as it requires SC removal (in which case I’d do the valley hoses in aluminum at the same time). Whew, says 8-12hrs labor at my indie shop. So a $2k job not including valley hoses.
Appreciate the feedback as always, gives me things to ask the shop this coming Thursday.
Old Aug 31, 2025 | 03:55 PM
CA Jag's Avatar
When I bought my car, brief but noticeable engine clatter for maybe 10 seconds just after starting. Always went away. PO obviously worried about it since he took it to the dealer and 2 great Indies for this reason. Car was totally babied. He'd driven it less than 2,500 miles in 3 years. No oil change. I changed the oil. Maybe new oil and/or weekly drives but after several weeks, noise was completely gone.
Old Aug 31, 2025 | 04:01 PM
CA Jag's Avatar
Smart to open hood. One guy in the X100 forum (Z-ray) put a fan on it as well.
Old Aug 31, 2025 | 04:16 PM
jahummer's Avatar
Had to replace engine and trans mounts at around 50K miles. Drive shaft coupler rubbers also prone to dry rot.
Old Aug 31, 2025 | 04:22 PM
guy's Avatar
guy
I think they provide therapy for that.
Old Aug 31, 2025 | 04:38 PM
ericmcn's Avatar
The PCV is located on the drivers side, USA; passenger side below the intake pipe - no need to remove the SC.
Old Aug 31, 2025 | 07:38 PM
guy's Avatar
guy
@Circumnavigator (incidentally, I am very much a sailor) fwiw, I use 0W20
Old Aug 31, 2025 | 07:49 PM
From what I've seen over the years in this forum, like air filters, we won't go down the oil rabbit hole.
Dm'd you about the sailing thing as I'm sure most of these guys don't want a derailed thread.
Sailing is Life.
Old Sep 1, 2025 | 10:38 AM
jahummer's Avatar
Not to start a debate, but the 4.2 should be 5W30, even in colder climes.
Old Sep 1, 2025 | 03:11 PM
ericmcn's Avatar
Whoever is using stupid oil grades is sending their Jag to an early death - its plastered on the oil filler cap - what oil to use
Old Sep 3, 2025 | 09:59 AM
sony2000's Avatar
When you engine shakes going down to idle, is the transmission engaged? A shake at that RPM can be a dirty throttle body valve.
Your small coolant leak maybe resolved by going over to Evan's coolant. No pressure!
Old Sep 3, 2025 | 10:25 AM
It is while in park. And very brief.
One of yuck shake when starting engine then one quick (but a second longer) shake when dropping to lower idle.
I’ll add the dirty throttle body valve to the list for the indie.
Evan’s coolant. Added to my notes. Thanks!
Old Sep 3, 2025 | 02:32 PM
guy's Avatar
guy
Getting back to the OP's "engine sounds",
My car with 192,000 kms purrs like a kitten, and growls when I make her earn her living. (which she needs to do frequently)
No unnecessary ticking, whirrs or taps. (Now that SCV6 in the LR4 is a different matter)
She has perfect cylinder compression and does not burn or consume oil.
Last oil analysis showed very minimal wear with no concerns.
But she does get an oil change every 5000 kms. (I think WSS M2C913-B is conventional oil) She only gets the full synthetic equivalent... and only ever did from 2500 kms. Yes, at 50,000 kms I moved to 0W20.
Most other fluids and filters are equally changed as frequently:
Brake fluid,
Coolant,
Differential fluid,
Engine air filter,
Fuel filter,
PCV valve
Power Steering fluid,
Super charger oil
Transmission fluid.
Fuel is strictly a Top Tier 91 or 93 octane. And very, very rarely with alcohol mixed.
Old Sep 3, 2025 | 05:18 PM
HealeyJag's Avatar
While mine is an XK..
Had a funny yesterday...
Tried to exit the car....
Didn't realize it was still running....thought I shut her down....
Ah..life is good!
No.. I'm not hard of hearing....
binkyting27
Aug 18, 2024 11:58 PM
pvxkowner
Mar 22, 2023 06:53 PM
curdi_sv8
Feb 17, 2022 10:05 AM
bigcatrescue
Jul 27, 2021 09:13 AM
lossking_
Aug 31, 2016 11:21 AM
