Exact difference between XKR and XKRS Exhaust
Old Sep 11, 2020 | 03:57 AM
  #41
Cambo's Avatar
Yes
Old Sep 11, 2020 | 04:02 AM
  #42
CH_XKR's Avatar
Originally Posted by Cambo
Yes
yeeay! Thank you!
Old Nov 10, 2020 | 05:01 AM
  #43
sbhumphrey's Avatar
Hi, I am new to this forum so I apologise if this has been asked before but.... In the diagrams I have seen to do the XKR to XKR-S exhaust modification it just shows the original internal pipes being cut off and removed yet in this photo they have been cut and rejoined much shorter, what is the reason for that?
Old Sep 28, 2024 | 07:13 AM
  #44
Gino944's Avatar
Originally Posted by CH_XKR
ok! just to be sure..
First picutre --> XKR
Second picture --> XKR-S / PAE
Hi, I just made 2000 miles to buy i think the wrong silencer... whats the difference between the 2 ? Someone say the external tube (where is the valve) have bigger diameter ?
There is less restriction inside the box ?
Thank's
Old Sep 28, 2024 | 07:37 AM
  #45
guy's Avatar
guy
You travelled 2000 miles to buy a used muffler???
Old Sep 28, 2024 | 09:27 AM
  #46
Cee Jay's Avatar
The pipes inside the R-S box are slightly different, one section is removed to make it just a bit more free-flow. The center resonators are removed and replaced with an X pipe, but that's not inside the box. I don't know about a diameter difference.
There are several photos posted in this forum, but I have no idea which thread. You could try different terms in the SEARCH function.
Old Sep 28, 2024 | 04:39 PM
  #47
Grimreaper's Avatar
Before Modifying !
After modification
Close up
Completed
There you go ! Modifying XKR to XKR-S
‘THEN FIT an X pipe rearward in front of rear axle.
‘hope this help you.
Old Sep 28, 2024 | 08:10 PM
  #48
Cee Jay's Avatar
Yeah, those ones. I was backwards though, the -S has an EXTRA pipe to dump exhaust.
Old Sep 29, 2024 | 05:00 AM
  #49
Grimreaper's Avatar
With exhaust valve opens it nearly all bypasses silencer / when closed 2 outer pipes are closed off with butterfly valves the S dost have any extra pipe ! Just routed different inside silencer. Also has X pipe to rear of car not the front to give it the distinctive sound.
Ended up with 592 BHP.
Remap / ported supercharger & polished/ 10% pulley/platinum plugs/hi flow air filters/cleaned airmass meters & Bosch hi flow water pump for charge cooler.
XKR’s struggle on rolling roads as they suffer very quickly with heat soak.
Old Sep 29, 2024 | 05:02 AM
  #50
Grimreaper's Avatar
one of my rolling road videos 👍🏻
Old Sep 29, 2024 | 05:05 AM
  #51
Grimreaper's Avatar
Old Sep 29, 2024 | 04:34 PM
  #52
LJRXKR's Avatar
Looks real nice in that blue.
Old Apr 14, 2025 | 09:32 AM
  #53
BagelConsultant's Avatar
@Grimreaper your car looks and sounds fantastic, I'm ordering the RPM Motorworks x-pipe for mine to wake the exhaust up a bit while keeping the OEM active backbox in place.
Just got her out of winter hibernation:
Schwabe
Nov 2, 2016 06:44 AM
Lothar52
Jul 7, 2015 01:10 PM
jagtoes
May 22, 2014 06:35 AM
Laslonimne
May 23, 2013 04:26 PM
Evoking
Mar 17, 2012 10:25 AM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
