First problem with new XK: water in the trunk
Old Feb 2, 2015 | 07:29 AM
earny's Avatar
Default First problem with new XK: water in the trunk
Hi colleagues, after a first weekend (with bad weather) I discovered my first problem of my new XK Coupe: water in the trunk. The "lowest" alcantara-piece on the left side is soaked at the bottom and the water flows/drips from the left shock absorber mounting into the trunk/area of the spare wheel. Not too much, but enough to not ignore it.
Is that a known issue and where can the water come from?
Thx in advance,
bernd
Old Feb 2, 2015 | 09:11 AM
amcdonal86's Avatar
What year is it? If it is an 07 I'd be supicious of the power antenna.
Old Feb 2, 2015 | 09:43 AM
earny's Avatar
Hi, thx. The car is a model 2008 with antenna in the spoiler - and the antenna of the up-to-2007 model should be on the right side, or?
Old Feb 2, 2015 | 03:45 PM
mosesbotbol's Avatar
Good luck.
Old Feb 3, 2015 | 03:06 PM
Ngarara's Avatar
I haven't heard anyone else talking about such a leak. The rear hatch is really good at dumping water/snow into the luggage compartment if you don't open it carefully & give it a few shakes before fully opening it, but I expect you'd have noticed that if it happened.
I guess it would be a good idea to carefully inspect the seals around the opening to see if any of them are split.
Old Feb 10, 2015 | 08:27 AM
earny's Avatar
Quick update: water has stopped, Sir! It was the seal of the left rear window.
Love to drive my XK every day - today back from the dealer on the "Autobahn" with low traffic...
bernd
Old Feb 11, 2015 | 10:23 AM
Lothar52's Avatar
bernd
I think I may have a left rear window seal problem as well... what all did it take to fix it!?!?
Old Feb 12, 2015 | 09:35 AM
earny's Avatar
Sorry, Lothar - I was in a hurry and did not ask in detail. Window obviously came out, a new seal and I believe the chrom around is also new. The Jag-dealer has fixed it and I have not payed the repair.
dsnyder586
Dec 29, 2024 07:39 PM
mbergen
Oct 23, 2019 10:26 PM
XJsc-guy
Nov 23, 2015 01:56 PM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
