Fitting coilovers?
Fitting coilovers?
Now I know this won't be to everyones taste. But I'd like to fit a set of coilovers to my 2007 XKR. It currently has electronic dampers and I'm pretty sure that unplugging them will result in some sort of error message. I'm thinking of the BC racing coilovers. Have had them on 3 previous cars and rated them highly.
so is there a way of avoiding the error message? I was suggested that unplugging the module for the suspension would solve it?
I guess a more relevant question is, are coil overs with the correct dampening and spring rates available for our chassis? My experience with motorcycles gives me a dim view on the available products. Mostly sale brochures described how parts were sold for their looks but not actually applicable for the intended use / duty. Before I would buy anything aftermarket, it would have fully adjustable compression and rebound dampening as well as adjustable bump stops. Then there would be a mechanism to swap out springs to find the correct rate that works with the needed dampening. Kind of like the 'tune' thread. It's damn near impossible for an aftermarket to tailor products to such a small percentage of potential sales.
TLDR, I think buying coil overs only to adjust the height is going about it the wrong way.
davchr (02-05-2018)
You need to pull fuse 14 from the drivers foot well.
Very interested in what results you see with the BCs. I had considered them however was told by a few motorsports techs to avoid them due to the old adage you get what you pay for. Spires does offer a set of custom bilsteins from the F type for about 4x the price but of significantly better quality.
For me coilovers have always been a huge improvement in ride quality compared to stock in the many cars ive owned. Especially when you start to learn how to adjust your dampers and figure out that perfect ride height. If I were to get coilovers I would have had bcracing-na.com make me a set, they do great work with quality coil overs.
