Flat Battery
Old May 19, 2023 | 07:11 PM
SoCal-LBC's Avatar
Default Flat Battery
2012 Jaguar XK
I let my battery go complete flat.
I don’t drive it as much as I should and usually keep it on a CTEK trickle charger but didn’t do it this time.
The battery seems completely flat (it’s the original battery). The trunk and doors are locked.
I was able to connect the CTEK to the emergency supplemental battery terminal under the driver side rear fender.
It initially didn’t take any charge but I found a better ground and it started charging.
Once charging all of the lights (headlights, taillights) started flashing and I could hear relays clicking. Seems like it was trying to reset?
I was able to open the doors but not the trunk.
The flashing lights and relay clicking didn’t seem good so I unplugged the CTEK.
What should I try next?
I could try to let the CTEK to keep charging?
I could also call AAA and get a proper jump.
Thanks!
Old May 19, 2023 | 09:05 PM
kj07xk's Avatar
You need more juice than what that CTEK is giving you to get out of that hole.
Old May 19, 2023 | 10:31 PM
Cee Jay's Avatar
What kj said, you need at least 10 amps.
Something like this will work.
Old May 19, 2023 | 10:33 PM
SoCal-LBC's Avatar
Yep, dug in deep.
I gave it another try and the electronics freaked out, typical low battery. I did manage to open the boot.
I can either try a real charger or get a high amp jump from AAA. Other option if I can get the boot open again would be to swap out with a new battery.
Old May 19, 2023 | 11:51 PM
kj07xk's Avatar
Originally Posted by SoCal-LBC
Yep, dug in deep.
You closed it? You probably don’t want to trust that battery, get a new one, and (I can hear some members screaming this) “charge that new battery fully before installing it”. Get yourself a ‘real’ battery charger, like mentioned above, it’s a great investment (bought mine, maybe 40 years ago, rarely used, but it’s there when I need it).
Old May 20, 2023 | 02:54 AM
RichardS's Avatar
Yep, dug in deep.
Your battery is so old that replacing it with a new battery is 100% required so shutting the boot again was a bit optimistic.
A CTEK is fine but it depends upon what model you have. Mine is a 10A CTEK smart charger which is permanently connected but also has a 10A supply setting so can be used as bulk, non-smart, charger in situations such as yours where the battery is so flat that a smart charger can struggle to start the recharge sequence.
Richard
Old May 20, 2023 | 08:29 AM
jahummer's Avatar
2012 Jaguar XK
So it's 11-12 years old? That might be a record!!! Most batteries last 3-5 years, I've been lucky a couple of times and managed as much as 6 years. Use and environment have a role in longevity as well.
Old May 20, 2023 | 09:36 AM
SoCal-LBC's Avatar
At least 10 years old so yes probably a record. I kept it on the CTEK and So Cal is relatively easy on the battery. No hard starts.
I probably could have gone longer if I remembered to but the CTEK back on.
  • Another lesson is that when the battery is this flat, disconnect the negative until fully charged again so the the electronics don't freak out.
Old May 21, 2023 | 06:41 PM
ralphwg's Avatar
I went with an AGM for my 2013 XKR.
George Abitbol
Jan 19, 2021 09:58 AM
rtcosic
XF (X260)
May 25, 2020 01:43 PM
gmsclassics
Jan 27, 2018 11:20 AM
Mark in Maine
Dec 31, 2017 06:06 PM
abela
May 21, 2013 11:48 AM
