Floppy Glove Box Door
Old Dec 30, 2023 | 04:56 PM
BLD's Avatar
BLD
Default Floppy Glove Box Door
I have a 2008 XKR with the floppy glove compartment door issue. I am trying to do the repair outlined in the Jag TSB .JTB000191/2010. I have instruction 76.52.03 to remove the glove compartment. This instruction says to remove the passenger side footwell trim panel (3 clips). I know there are several threads on this issue but it is not clear to me which panel to remove. Which panel are they talking about?
A previous owner made the repair described in the TSB. What I have found is the damper arm is broken clean off from the glove box door. So I will need to devise some way to reattach or glue the damper arm back on or replace the glove box completely (used on EBAY at $445, ouch!).
Thanks for any help given.
BLD
Old Dec 30, 2023 | 05:04 PM
kj07xk's Avatar
It’s the soft panel above the passenger feet, the 3 clips, along the bottom edge of the glove box, squeeze to release.
Old Dec 30, 2023 | 05:08 PM
ram_g's Avatar
@BLD see this thread where I have documented my fix to the exact same problem of the arm breaking off from the door. Please note my comments on the actual damper mechanism having a lot of stiction which I think is the root cause of the failure.
3 months on my glovebox still works fine.
Glovebox - 1 step forward and 2 very large steps back - Jaguar Forums - Jaguar Enthusiasts Forum
Old Dec 30, 2023 | 05:45 PM
BLD's Avatar
BLD
Yup, mine looks just like your pictures. I will check out my damper too. Thanks.
BLD
Old Dec 30, 2023 | 05:55 PM
BLD's Avatar
BLD
My panel is missing completely! Maybe that is why I didn't understand what the instruction was talking about.
Andyzjag
Dec 5, 2023 10:11 PM
tommyd
May 17, 2015 10:00 PM
al_roethlisberger
Jun 14, 2014 08:42 AM
sws805
Dec 14, 2012 09:36 PM
Walter1982
Feb 15, 2009 07:02 PM
