Front left headlight intermittently failing
Old Apr 9, 2019 | 07:14 AM
Ter11's Avatar
Default Front left headlight intermittently failing
Hi all
Anybody here is familiar with the following headlight issue?
Seldomly - like once a week - the low beam headlight on the driver side does not work. All other lights do work. And interestingly there is NO FAILURE MESSAGE in the dashboard informing about a failed bulb or similar.
Therefore it is only in absolute darkness or when the headlights mirror in the car in front when I notice that the left headlight is off. When I then cycle the lights on/off, the left headlight is usually back to work.
Any ideas??
BR
ter
Old Apr 9, 2019 | 07:25 AM
110reef's Avatar
Sounds like time for a new bulb.
Old Apr 9, 2019 | 09:11 AM
Ter11's Avatar
Thanks! Did you have a similar experience? I would have expected that the car provides a message in case of failed bulb...
br
ter
ps: just watching Jay Leno driving around in a white E Type coupe on YouTube. Great watch...
Old Apr 9, 2019 | 10:26 AM
Queen and Country's Avatar
Try turning on and off when problem occurs, if it comes back on, its the ballast (driver for hid)
Old Apr 9, 2019 | 11:34 AM
Ter11's Avatar
Thats exactly what happens. If I turn it off/on it works again. So new ballast. Thanks!!!
br
ter
Old Apr 9, 2019 | 01:46 PM
HIDs need real high voltage. What's happening is that the capacitor is only partially charging on the first go around, not enough for a power on. Over time the capacitor will only get worse. Caps have a lifespan.
But in this case it seems to be isolated to a less than perfect cap.
Those damn Brits with their fat greasy fingers from the chips, covered in circuit destroying salt and vinegar and only newsprint to wipe with.
Old Apr 10, 2019 | 01:41 AM
neilr's Avatar
Hella lights? I would have expected that it was a big German spilling his Sauerkrat all over the board
xenophobe
Dec 6, 2015 12:49 AM
Anfield Dreaming
May 4, 2015 12:34 PM
andrewba
Dec 20, 2014 07:39 PM
99xk8
Dec 14, 2012 08:55 PM
Dallas4lr
May 6, 2008 05:08 PM
