frozen screen
Old Apr 30, 2023 | 03:52 PM
d a's Avatar
d a
Default frozen screen
After sitting awhile I took the Jag out and while trying to pair my phone I got this locked screen which won't go away. I tried entering the code I tried turning the car on and off and on again, still no change. Big brains, what gives?
Old Apr 30, 2023 | 03:59 PM
Cee Jay's Avatar
Do a Hard Reset: Disconnect both car battery cables and touch them together for about ten seconds. Completely avoid touching the battery.
Old May 1, 2023 | 11:48 AM
Stuart S's Avatar
I suggest that you start the Bluetooth pairing process over from scratch, by deleting your phone from your XKR and your XKR from your phone. Reboot your phone after you've cleared it and before you try to pair it to your XKR.
You didn't tell us anything about your phone - iOS/Android. the make, model, and age. If it's new, it's possible that it won't work with your XKR as your car and Bluetooth module are 13 years old.
See this old thread (it's in the Stickies):
https://www.jaguarforums.com/forum/x...jaguar-152361/
Good luck!
Old May 2, 2023 | 07:13 AM
guy's Avatar
guy
Yes, Bluetooth has gone through constant improvement over its lifespan but it is “mostly” entirely backwards compatible when it comes to mobile phone device connectivity and the functionality associated with that.
I would be very surprised if your phone cannot connect for telephony purposes. But as suggested, clear the necessary previous settings and then initiate the pairing process.
If you have multiple devices paired, there is no need to remove the unrelated profiles.
Old May 3, 2023 | 02:23 PM
d a's Avatar
d a
Thanks for all the input guys. Actually let it sit overnight and everything started and connected as it has for the previous 3 years. Not sure how sitting for a couple of months affected a phone hookup that had worked for three years so far. Anyway, found a Utube that suggested holding the infotainment power button down for about 10-30 seconds should also work. Thanks again.
Old May 3, 2023 | 07:40 PM
u102768's Avatar
It was probably just caused by a module that didn't start up properly. Just turning the car off and on won't reset the modules as they stay awake but locking the car and leaving it for half an hour should do the job.
needanswers
Aug 28, 2023 09:12 AM
Hockey_Steve
Jan 25, 2023 10:11 AM
Buckingham
Oct 11, 2021 05:13 PM
Wade Brooks
Aug 2, 2020 06:47 PM
RossBW
Nov 4, 2019 04:27 PM
