Fuel Trims and Timing Advance Q
Old Jan 25, 2025 | 12:54 PM
ericmcn's Avatar
I have the engine cover trays and crap removed from this Engine and suggest others should do likewise, it gets extremely hot...
Old Jan 27, 2025 | 10:04 AM
JagV8's Avatar
It's designed to run hot.
Your car, though, so up to you.
Old Jan 27, 2025 | 10:29 AM
ericmcn's Avatar
Designed to run hot? Why is there cooling vents on the bonnet?
Nobody engineer's a product to run hot, remove heat, yes.
Old Jan 28, 2025 | 10:13 AM
JagV8's Avatar
It's designed to run hot but not too hot and the vent may be useful or just vanity.
Old Jan 28, 2025 | 12:48 PM
ericmcn's Avatar
I take it you are not an Engineer <of any sort> ? Heat is a killer and its why the Vacuum lines wrapped in heat shrink are perished and why theres two large holes in the bonnet - I suggest you walk under the Engine of a XKR after its out on a run under a ramp and see how you feel.
To update the fuel trims, I fitted C2P3419 and bodged a 3mm hose to replace AJ811093 as that part is back ordered - I have been looking at the fuel trims as its takes a number of cycles for the LTFT to even out and they are now close to 0 at idle, fluctuating around +/- 1 percent or so. So the Vacuum hose was the source of the lean fuel trim.
I will do a better bodge over the weekend with better quality silicon cut to the correct lenghts as the OE pipe, which I probably do not need anymore
Old Jan 28, 2025 | 01:19 PM
ericmcn's Avatar
Old Jan 28, 2025 | 01:25 PM
McJag222's Avatar
Hot is better if you are running a steam engine. I took off the engine cover shortly after buying the car. When that plastic hose crapped out fitted around the supercharger I could hear the hissing noise. I too did a "bodge" fix using clear hose. Worked well. I eventually replaced the assembly with the original part.
Joel Brown
46
May 9, 2021 09:47 AM
dirkroels59
Mark V - X 420G
Jul 12, 2020 12:52 PM
Boomer from Boston
33
Jun 11, 2017 09:13 AM
1970WillowGreen
E type ( XK-E )
Dec 13, 2015 01:14 PM
cartopics
Nov 24, 2015 01:29 PM
