Gearbox oil
Old Jan 2, 2018 | 10:33 AM
Tatty's Avatar
Default Gearbox oil
I was at the dealers the dealers today and asked them about changing the gearbox oil and filter as I’ve just got 60,000. They said it’s a sealed for life unit. I told them ZF recommend it and they disagreed. I have an extended warranty with them and they said if anything went wrong I’d still be covered. Has anyone else asked dealers about doing this work? I’ve had nothing but bother with mine and I don’t trust them one bit!
Old Jan 2, 2018 | 10:40 AM
Mufc's Avatar
Use one of the ZF authorized shops to do this for you. Hopefully you will have one close by. If not, these transmissions are used to loads of cars including BMW's etc a good specialist Indy can also help you.
Old Jan 2, 2018 | 10:45 AM
Tatty's Avatar
Yeah I was just wondering if other dealers recommend it that’s all as I don’t trust mine.
Old Jan 2, 2018 | 11:30 AM
mosesbotbol's Avatar
Have an indy repair shop do it. The parts are sold as a kit which includes the pan-filter and fluid. This forum has a sponsor that is a big ZF supply shop. All in the job is around $500 and well worth it. Make sure it is from an official ZF reseller as I have read there is a lot of counterfeit ZF fluid on the market.
Old Jan 2, 2018 | 11:42 AM
JagV8's Avatar
Jaguar's tech site for dealers says to change it but dealers are often hopeless. Go elsewhere. Find a gearbox company or a competent jag indy!!
Old Jan 3, 2018 | 12:11 PM
clubairth1's Avatar
Community Influencer
Remember to change the electric plug sleeve while you do the service. It can't be changed unless you drop the pan. It's only about $15 so it's cheap to replace.
This might even be leaking right now as it's VERY common.
Old Jan 3, 2018 | 01:34 PM
SinF's Avatar
Sealed for life [of a new car warranty]. Change the oil if you want it to last past the warranty.
Qvhk
Jan 1, 2018 10:10 AM
jagosaurus
Jan 10, 2013 12:55 PM
jagmanxj8
Jul 6, 2010 10:36 AM
riz325
Dec 22, 2008 07:24 PM
