Got bored...LEDs
Old Oct 13, 2025 | 11:55 AM
Circumnavigator's Avatar
Default Got bored...LEDs
So I got bored while waiting on my appt to replace the engine trans mounts at the Indy.
Ordered some LEDs for the interior parts and watched a couple of videos.
The 501s / W5W / T10) were easy to find. I ordered CANBUS safe to avoid flickering.
The festoons were more of a challenge. 38mm and 44mm are not very common.
I ordered 2-3 of each type just in case in a couple of close sizes. And its amazon. So the ones I don't use will just go back.
6000 kelvin across the board.
Still waiting on the 38mm festoons for the boot and puddles, they arrive in a few hours.
*** Arrived ***
Some fun notes:
Glovebox (T10) - Gotta have tiny fingers. I don't. By the time I almost got a grip on it, I got a nice blister. Skipping this one, but probably have to remove entire glovebox to replace or sort out how to turn the light off with the glovebox open.
Puddles (38mm) - Swapped out from the original custom Jag logo door lights. Much better.
Overhead light (44mm) - I found a 44mm festoon, linked below. Only a couple out there. The contacts get loose and most LED contacts are more narrow. A gentle squeeze to tighten them up with a needlenose works great. If you've never removed that overhead console, be very careful when putting it back. There are 4 contact pins for the circuit board that have to align perfectly and will bend easily.
Map Lights (T10) - Man those are in there tight. But got them out and the new ones in with a little force.
Footwells (T10) - Fairly straightforward. But hilariously, as my 6'3" frame lay upside down in the driver's footwell, I got stuck for about 4 minutes until I realized I could raise the steering wheel up and in. No panic, I'm too old for that. Just chilled down there for a minute and cleared my head. (the driver's door is too close to the concrete garage wall, so I had to climb over the console.)
Boot lights (38mm) - Very easy to swap. Put the first one facing backwards and couldn't figure out why it wasn't brighter than the original. Spun it around and very nice.
There is a site out there that sells good quality LED sets for the jag, in the exact sizes, but by the time I selected all the above mentioned, it was almost $100 and days to get here.
Amazon Links:
Overhead Light:
44mm -
Amazon Amazon
< Used these
42mm-
Amazon Amazon
< Should fit but will send back
Glove/Map/Footwell:
T10 -
Amazon Amazon
< Used these
T10 -
Amazon Amazon
< Will send back
T10 -
Amazon Amazon
< Will send back
Boot/Puddle:
39mm -
Amazon Amazon
< 39mm fit just fine! Not much brighter than originals, but clean.
39mm -
Amazon Amazon
< Arrives tomorrow. Will return unless today's don't fit
Cheers!
Old Oct 15, 2025 | 09:04 AM
Parzival's Avatar
worthless without pictures
Old Oct 15, 2025 | 11:35 AM
Yeah, as soon as I finished swapping I was mad at myself for not taking before and after pics.
if anyone is interested in seeing just after pics, I can do that.
Old Oct 16, 2025 | 07:40 AM
Stucciarello's Avatar
We all know what the before pictures look like. Send the after pictures.
Old Oct 16, 2025 | 10:16 AM
Ask and you shall receive.
Old Oct 16, 2025 | 10:25 AM
Now I am looking for vids on how to replace the side lights (2007-2009 side vent). No idea how to get in there.
Then it will be the headlights and tail lights.
Old Oct 16, 2025 | 12:05 PM
Cee Jay's Avatar
Quite vibrant now, huh? That'll help you out a bit when you do the interior detail that is overdue. Mine needs one also.
Old Oct 16, 2025 | 12:21 PM
One of my favorite upgrades so far.
About that interior detail. Brilliant of you to notice. I’ve been saving this one as a new post. And will save it a bit longer, but I have a ton of questions about what can and cannot be fixed in there.
Staying focussed on 2-3 things at a time though.
But yeah, lots of knicks and rubs.
These on both sides bother me the most:
Flint Ironstag
Oct 15, 2025 03:32 PM
CorStevens
May 23, 2021 01:15 PM
Lookout!
Dec 17, 2015 09:57 PM
MarcusXFR
XE ( X760 )
Oct 2, 2014 07:53 PM
