Ground Points
Old Mar 22, 2021 | 10:00 AM
TVR-Schleicher's Avatar
Default Ground Points
Hello,
my Name is Tom, I live in Germany and I own a 2013 XK. I love the car and I'm going about 15000 mls/y mostly on the Autobahn. The car works well, but I get a lot of code faults with my semiprofessional code reader (no obvious malfunction). The battery seems to be good. My idea is that any ground point has gone bad. Therefore I want to inspect the factory ground points. The XK electrical guide shows the ground symbols but does not inform about their location in the car.
Does anybody know where the ground points are located?
Excuse me for my bad english.
With Kind Regards
Tom
Old Mar 22, 2021 | 11:08 AM
Tom,
I often find lots of codes have been recorded when I run an SDD session. Many are not errors but simply "out-of-range" readings which record a diagnostic code. If the vehicle is running well, you could be looking for trouble that is not really there.
Here's an example of a check session on my XK:
Lots of codes listed but nothing there to worry about.
Old Mar 22, 2021 | 11:42 AM
MarkyUK's Avatar
A couple of things confuse me, namely:
1) You say "The battery seems to be good" how do you know? How old is it, ,do you load test it or have it on a CTEK maintainer regularly?
2) Why have you not had a screen name like ;XK- Schleicher?
Old Mar 22, 2021 | 12:31 PM
Hello Graham,
some of your codes are also present in my car. I am calmed down.
Hello MarkyUK,
1) The Battery is 1/2 year old and every 2 weeks it is on a CTEK. 2 times per week I go for 100 mls and I have nearly no short distance trips. So I think the cause is not the battery.
2) I own a TVR Griffith (1994), too. Years ago I joined the german TVR Car Club. They called me "TVR-Schleicher" because I was the slowest on the road (translated "TVR-creeper"). Over the Years I got used to this name.
Tom
Old Mar 22, 2021 | 06:44 PM
MarkyUK's Avatar
I knew what it meant as am multilingual (Can sing Wooden Heart in English and German) you omitted that it is 'silent but deadly fart' btw
Which wouldn't do for for an XKR...wait hold up you've got an XK, so it's fine!
Old Mar 22, 2021 | 06:59 PM
Cee Jay's Avatar
Still though, to go along with the Thread Title, where ARE the ground points exactly???
Old Mar 23, 2021 | 12:21 AM
u102768's Avatar
Does yours not have this list?
File Type: pdf
Old Mar 23, 2021 | 12:25 AM
u102768's Avatar
This is for the earlier cars but may help you locate some of the earths listed in the other document I posted.
Old Mar 23, 2021 | 05:16 AM
Many thanks u102768, very helpful!
vsol
Oct 3, 2019 11:23 AM
egovreau
XK120 XK140 XK150
Nov 21, 2018 08:46 PM
LeLimoMan
Jul 30, 2016 05:47 AM
petemohr
Mar 27, 2014 08:57 AM
manicguitarist
May 23, 2012 10:30 PM
