haunted
Old Jan 30, 2017 | 09:46 AM
cj005's Avatar
Cool haunted
2008 XK 23k won't shift out of 1st gear in D mode whats up ?
Old Jan 30, 2017 | 12:02 PM
Cee Jay's Avatar
Have you tried the paddles? How about SPORT and the paddles? Have you noticed any oily substance underneath the center of the car while it was parked?
Old Jan 30, 2017 | 12:08 PM
cj005's Avatar
stopped and went from N to D while stopped a couple of times then it worked correctly ?
Old Jan 30, 2017 | 12:22 PM
cj005's Avatar
no leaks
Old Jan 30, 2017 | 04:12 PM
Cee Jay's Avatar
Check Your Battery!!!
Use a CTEK or equivalent Battery TENDER!!!
Nearly every problem with these cars is due to low voltage.
Old Jan 30, 2017 | 04:16 PM
cj005's Avatar
ill just go to the jag dealer $240 for a batt $70 installed
Old Jan 30, 2017 | 04:43 PM
ralphwg's Avatar
Buy a CTek and comfort extension on Ebay or Amazon for under $100. Install in about 15 minutes. Plug in and turn on when XK is not in use about 30 seconds and your low voltage problem is completely solved. But, on the other hand maybe the battery needs to be replaced. How old is it? If it is more than 4 years old I would replace it.
There are several threads dealing with XKs and low voltage issues. Suggest you read through one or two and you will get the picture.
Old Jan 30, 2017 | 09:47 PM
jahummer's Avatar
Did you accidentally bump the paddle shifters? The intrument cluster display will indicate which gear you are in or if you are in automatic D or sport DS. Pressing and holding the right paddle will return the car to automatic or shifting to neutral then drive will do the same.
Old Jan 30, 2017 | 09:53 PM
Cee Jay's Avatar
Originally Posted by jahummer
Did you accidentally bump the paddle shifters? The instrument cluster display will indicate which gear you are in or if you are in automatic D or sport DS. Pressing and holding the right paddle will return the car to automatic or shifting to neutral then drive will do the same.
Bumped mine many times.
Old Jan 30, 2017 | 09:58 PM
cj005's Avatar
don't think so. but I don't know how old the batt is so ill take care of that in the morn with
a new one and check the charging sys thanks
