Headliner let go (alacantara)
Old Apr 29, 2024 | 07:32 AM
lear60man's Avatar
Default Headliner let go (alacantara)
I have the ivory leather and light grey alcantara/suede headliner. I need to source matching material as I dont want to redo all the pillars and sun visors. Is Tberg still the go to guy? If I did have to redo everything, I would go with an ivory color but dont know if the sun visors can be done to a level that looks factory.
Old Apr 29, 2024 | 07:45 AM
guy's Avatar
guy
I took a different path. Much less than a 1/2 day job….
Dropped the headliner
Pulled off the fabric
Cleaned the foam from the headliner
Used 3M spray on adhesive
Laid the original fabric back on
Reinstalled the headliner.
Old Apr 29, 2024 | 09:12 AM
Cee Jay's Avatar
To do this you need the right 3M spray, as only one of their sprays works on headliners. The others all let go in short order. I disremember which one specifically.
Old Apr 29, 2024 | 10:21 AM
bocatrip's Avatar
. I also used my original headliner when repairing mine a number of years ago. I did have the foam replaced. I believe that with or without foam, the trim pieces need to be removed to do the headliner properly. I was lucky enough to have the visors ( which most installers don’t want to touch) redone with the existing material. The trim pieces were also cleaned and reglued as they get droopy. It was still time consuming. Although not perfect, everything did match.
Old Apr 29, 2024 | 11:59 AM
guy's Avatar
guy
deleted pic as I don't want to be responsible if someone purchases it and is unhappy.
Old Apr 29, 2024 | 03:00 PM
Cee Jay's Avatar
NNOOOOOO!!!!!!!!
That will not hold! It even states such on the can. "Not for headliners".
You need the best you can get for under too much $$$...
90 would probably work also.
Old Apr 29, 2024 | 04:15 PM
guy's Avatar
guy
I know... but there is no foam and its held for more than a year... fine.
If it didn't hold I was going to change all the cloth as opposed to reglue the original. OK, 94 for next time!
Old Apr 29, 2024 | 08:00 PM
McJag222's Avatar
Dis say's it's headliner glooo:
https://www.autozone.com/sealants-gl...8oz/110464_0_0
Old Apr 29, 2024 | 10:10 PM
lear60man's Avatar
I have some Willwood adheasive in the garage. Gotta read the directions to see if it works well. If not thanks for the options. My interior guy said he is out for 3 months....so looks like Im gonna tackle this myself. Its not the difficulty but a time management issue as there are other (cars/boat) that need attention more.
Old Apr 30, 2024 | 08:22 AM
guy's Avatar
guy
Sailboats?!?
Old Apr 30, 2024 | 09:19 AM
ExKayRick's Avatar
Guy:
I did a thread on replacing my headliner and it's in the "STICKY" section, (8. INTERIOR). Titled: Headliner Refurbishment. I reside in the wacko state of California where the above-mentioned 3M spray is not an option, but I found another good adhesive that holds.
Tberg resides close in Los Angeles, so he recommended a place in San Diego, CA, that had a perfect match and various shades of headliner material. UFO Upholstery Factory Outlet in National City, CA.
I included lots of pics and step-by-step instructions in the Sticky. Feel free to DM me if you have any questions. Rick D
Old Apr 30, 2024 | 09:45 AM
Gator8's Avatar
I had the alcantara headliner replaced in my XFR by a local independent trim shop for less than $350, and the match is nearly perfect. The same shop installed a new top on my XK.
Old Apr 30, 2024 | 11:43 AM
McJag222's Avatar
I decided to replace mine with a new headliner. The only unit available was a grey/ebony XKR-S headliner) took about 3 hours in and out. My intention is at some time to remove the foam from the old headliner and re-glue the Alcantara as I'm not sure how long the new unit will hold up.
Just after the install - purrfect match:
Old May 2, 2024 | 04:15 PM
16fnrbrg's Avatar
I have twice been pleased with my local auto upholstery shop. Matched fabric, couple hours later it was done.
Ubad2
Jan 22, 2025 08:24 AM
prettybluefin
Apr 30, 2017 01:36 PM
v0lten
Jun 17, 2013 10:06 AM
mgb4tim
Jun 15, 2012 10:24 AM
