Help is needed
Old Dec 27, 2023 | 06:32 PM
JaggyBoii's Avatar
Default Help is needed
What is that hose next to my oil filter? Seems to be leaking, I really only notice the leak after I have used the defrost feature. The defrost does work but from what I can tell that is when the hose wants to leak oil.
Old Jan 2, 2024 | 06:43 AM
guy's Avatar
guy
That is not your oil filter. Do enjoy a glance at the workshop manual. It really is a good read.
Btw, its a coolant hose.
Old Jan 2, 2024 | 07:09 AM
sony2000's Avatar
As guy says it is a coolant hose that has a small leak. I think it is acceptable to "double clamp" the connection, and clean up the spillage.
Time will tell if it works. Add a more conventional stainless clamp, that closes with a ratchet or screwdriver, between the old clamp and the end of the hose.
Old Jan 2, 2024 | 09:37 AM
Cee Jay's Avatar
That painted blue cylindrical thing sure LOOKS like an oil filter. It probably has oil in it also. But yeah, that's coolant dripping, not oil.
I think Guy missed the blue part.
Old Jan 2, 2024 | 10:44 AM
Sean W's Avatar
That is an oil cooler and it looks like oil leaking to me, not coolant. Prolly @ the filter.
Old Jan 2, 2024 | 10:45 AM
sony2000's Avatar
On second look, yes the spotting is dark like oil. Oil drips when changing the filter above.
Old Jan 2, 2024 | 01:51 PM
Cee Jay's Avatar
Ya fooled me then, my oil cooler is in a different spot. Also the filter, but I knew that already.
Old Jan 5, 2024 | 06:03 PM
JaggyBoii's Avatar
Default diagnosis
Hello again guys, but the update to the situation is my oil cooler housing is what's actually leaking. I've parked the car until March but I will see to that repair. Sound about right?
Old Jan 5, 2024 | 06:45 PM
Cee Jay's Avatar
My oil cooler leaked also, but it was coolant and not oil.
Old Jan 5, 2024 | 08:02 PM
JaggyBoii's Avatar
It seems like mine is leaking oil. This is my first car so I'm trying to learn as much as I can. I'm also getting an oil change with the oil cooler housing replacement.
Old Jan 5, 2024 | 08:34 PM
jahummer's Avatar
When servicing anything regarding fluids it’s always prudent to throughly clean the area, not just to be tidy, makes watching for and identifying leaks easier.
Old Jan 5, 2024 | 09:40 PM
sony2000's Avatar
I can still say that the oil stains are coming from the spillage in changing the oil filter, or the occasional sweat coming from the oil filter seal.
ray13
Mar 28, 2023 07:18 PM
perfectphoto
Dec 16, 2021 07:14 PM
stran0020
Oct 26, 2021 06:25 AM
Waxa
Dec 6, 2020 04:16 PM
elindo
Dec 28, 2016 08:15 AM
