HELP: Is there a simple A2DP Bluetooth Music stream solution ?
Old Dec 21, 2014 | 02:12 PM
  #41
Ngarara's Avatar
So, it doesn't work with a 4S directly, nor with a 6 via a Lightning-to-32-pin adapter, nor with the WMA1000. That suggests it isn't the connected devices, but something wrong with either the cable or the Auxiliary Input Panel. I had some issues with my iPhone playback and the charging function stopped working, so they replaced the panel - problem solved.
Old Dec 21, 2014 | 03:49 PM
  #42
jehart49's Avatar
Default Another option
I took a lazy and cheap option and got an FM transmitter that plugs into the cigarette lighter. It has a cable interface to my Android phone and also a USB port. Quality isn't great but between engine and road noises, I'm not sure that I could tell the difference with the more sophisticated solutions. It plays Pandora and music stored on the phone just fine. $10 for the transmitter and 5 minutes to get the FM station set.
Old Dec 21, 2014 | 04:29 PM
  #43
vtech's Avatar
Believe you are right. The vehicle is still under warranty and plan to take to dealer at this point.
Thanks for all your follow up - agree either a bad cable or Port - they can troubleshoot and replace at this point
Keep you posted
Old Dec 21, 2014 | 09:34 PM
  #44
Rw99's Avatar
Yah, the iPhone (any version) should be seen as an iPod by the car when connected via the cable. And playback in that configuration should always work.
Might be helpful to bring your WMA1000 along to the dealership and try your setup with other used Jags on site...
Good luck!
Rich
Old Dec 22, 2014 | 12:32 AM
  #45
vtech's Avatar
Good Suggestion, thanks Rich
Ted
Old Dec 26, 2014 | 09:58 PM
  #46
vtech's Avatar
Default follow up
Good News to share with everyone. The problem with my vehicle was a bad I Pod cable that was in the vehicle. Had the dealer check out today and they replaced the cable with a new one under warranty
My I Phone 6 and WMA1000 is functioning like a charm when in the I Pod mode. Runs off the steering wheel controls and everything
Just FYI and thanks for all your knowledge on the threads
Vtech
Old Dec 27, 2014 | 04:47 AM
  #47
Ngarara's Avatar
The cable is very stiff, which means it tends to get bent awkwardly at the end, and I think that imposes stress that tends to contribute to failures.
Old Dec 27, 2014 | 12:06 PM
  #48
Rw99's Avatar
Excellent news, good to hear!
Rich
Old Dec 27, 2014 | 04:02 PM
  #49
vtech's Avatar
Default follow up
I was told in my case one of the PINS was bent. Glad it was a easy fix and everything else checked out
Old Oct 28, 2015 | 05:37 AM
  #50
Nosferatu's Avatar
2010 XKR owner here interested on the subject, but a little late to the party.
Now I see that they have Tune2Air WMA3000.
WMA3000A:
Compatible with Audi, Mercedes and VW with the original multimedia port for iPod options:
● Audi – Audi Music Interface (AMI)
● Mercedes – Media Interface
● VW – Media-In Multimedia Port (MDI)
has anyone tried this model?
Old Oct 31, 2015 | 07:38 PM
  #51
JustNiz's Avatar
I have the optional Jaguar Audio Connectivity Module in my 2008 XKR, and one of these plugged into it:
"><img src=" /> ">
Amazon.com:  Miccus Mini-jack RX: Bluetooth Music Receiver pair it with Phones,  Tablets, PCs and Apple Devices: MP3 Players & Accessories Amazon.com: Miccus Mini-jack RX: Bluetooth Music Receiver pair it with Phones, Tablets, PCs and Apple Devices: MP3 Players & Accessories
It works great.
If the 2010 XKR has a way to get an analog audio signal into the system (e.g. an apple connector adaptor) then you wouldn't need the Jaguar Audio Connectivity Module.
Old Nov 2, 2015 | 09:41 AM
  #52
robbing's Avatar
Do the bluetooth connections like this one mentioned above, Tune2Air WMA1000, connected directly to the 30-pin iPod cord, charge while connected to the 30 pin or do you have to remove it to charge it?
Old Nov 2, 2015 | 10:56 AM
  #53
Cee Jay's Avatar
Three entire pages and nobody said the obvious best choice;
Buy a five dollar USB Flash Drive and put all your music on it. THEN, stick the drive into the USB port and LEAVE it there (until you want to put another couple thousand songs on it) and it will play flawlessly. Why go about all the horrible bugginess of an iPhone or the hassle of plugging/turning on every phone? Keep your phone in your pocket where is SHOULD be and BT it with your phone system only. The flash will always be there and it interfaces perfectly. I have about ten thousand songs on my Flash and it's not even 1/4 full yet.
Old Nov 2, 2015 | 01:23 PM
  #54
robbing's Avatar
On the other side of this-I can't believe anyone still buys music or downloads it. I literally stream everything I listen to from the internet. I don't think I've actually purchased a song in 5 years, probably longer. I run Kodi on my phone and listen to whatever I want to listen to.
Old Nov 2, 2015 | 02:05 PM
  #55
jagtoes's Avatar
On the way other side I only use the AM/FM and maybe a CD once in a while.
Old Nov 2, 2015 | 04:41 PM
  #56
ralphwg's Avatar
What no Sinatra on Sirious 71??
Old Nov 2, 2015 | 05:25 PM
  #57
Cee Jay's Avatar
Buy? Who BUYS? All 10k songs I have were free. Between spending a couple minutes to burn a few hundred off CDs a decade ago, I've gotten every one for zero dollars. Streaming is weak (take 'weak' whichever way[s] you wish), and then you have to deal with stuff you don't like and those idiotic commercials. Me, I have nothing but the music I WANT to have and ZERO commercials. Also, no using a phone via Bluetooth or tethered, which is archaic. Mine is a part of the car.
Old Nov 2, 2015 | 08:05 PM
  #58
jagtoes's Avatar
I'm not that old , hahahah
Old Nov 2, 2015 | 09:56 PM
  #59
tampamark's Avatar
This is a great solution for music, actually I have a spare 160gb laptop hard drive and a USB to Sata adapter that works perfect.
The problem we have is the Wife has the XK as a daily driver and listens to Audible audiobooks. They play through the phone app and keeps the previous listening position, plus the file has DRM specific to Audible. So no direct play from memory stick or hard drive.
My best solution so far is bluetooth streaming receiver hooked to a RF Transmitter in the glovebox. Since it is an audiobook no problem for quality.
Old Dec 3, 2015 | 01:08 PM
  #60
xk6gr's Avatar
Hey, so I have a 2007 xk model, without the iPod or usb inputs and I want to play music through my iPhone, is there a solution?
