Help with wiring please
Old Oct 8, 2019 | 06:08 AM
barnsie's Avatar
Default Help with wiring please
Hi guys, I am trying to figure out which wires connect to the reversing lamp of my 2008 model XK-R. I want to hook up a reverse camera, so I need to tap into the feed which activates the reverse light when I select reverse on the shift.
The photos below show the left hand side of the interior of the boot/trunk with the access panel removed. Can anyone identify the colours of the wires which feed the reverse light - positive and ground? Many thanks in advance.
I know I could do some further dismantling to access the actual reverse light bulb and then trace the wires back from there, but I am trying to avoid disturbing things unnecessarily. Thanks again.
Old Oct 8, 2019 | 10:26 AM
gkubrak's Avatar
The electrical diagram should tell you. I would download a copy before you do any type of electrical work.
Old Oct 8, 2019 | 11:29 AM
arenaej's Avatar
Here ya go!
Old Oct 8, 2019 | 11:53 AM
barnsie's Avatar
Many thanks. That looks like Black and Black/White then if I am reading it properly?
I just checked and I do indeed have a B&W and a Black wire in that bunch. Would I be right in thinking that the Black would be ground and the B&W would be live?
Old Oct 8, 2019 | 11:55 AM
arenaej's Avatar
This might help too.
Old Oct 8, 2019 | 12:21 PM
arenaej's Avatar
barnsie, I see it differently, but I’m not an expert at reading these schematics. I had expert help doing mine. Perhaps there’s another set of eyes on here. I don’t want to muddy the water.
Old Oct 8, 2019 | 01:08 PM
TexasTraveler's Avatar
Hell I will muddy it up, to me it looks like BW is the ground and the OG or Orange/Green would be your positive trigger wire...
Old Oct 8, 2019 | 03:11 PM
barnsie's Avatar
Old Oct 8, 2019 | 03:16 PM
barnsie's Avatar
Thanks for the input - appreciated. Yes, now you have mentioned it, it looks to me as if OG is the live wire and BW goes to ground. As you can guess, I am not very experienced with car electrics or wiring diagrams .
I can always get an auto electrician to do the wiring for me - just thought if it was straightforward I could save some money...
Old Oct 8, 2019 | 03:53 PM
michaelh's Avatar
^^This.
Old Oct 8, 2019 | 05:14 PM
Sean W's Avatar
Well also, you're looking at a wiring diagram for 2010 onward. You have an 08? I dunno if the wiring is different but do yourself a favor and download the manual for your model year, here, free:
find your year and click on the link
http://www.jagrepair.com/JaguarXKXKR...OBDIIcodes.htm
Rezzz
Jan 31, 2019 06:07 PM
Gophat
Jul 28, 2018 12:37 AM
marvin67
Jun 3, 2017 03:46 PM
adenshillito
Feb 28, 2016 02:27 AM
MK2
Jan 19, 2014 11:50 AM
