Hesitates a second then thumps into gear
Old Dec 8, 2020 | 04:17 PM
gkubrak's Avatar
Originally Posted by Paul XK8
I have the same problem with my 2003 XK8. I drive it less than 1,000 miles a year. It only has 25,000 miles on it and I've noticed it since I bought it four years ago. In my case, the jolt after a slow rolling stop can be really bad. The engine will briefly speed up as I step on the gas while still barely moving and then will engage with a real kick. For a moment it seems the engine and transmission aren't connected. It also seems that if I come to a dead stop there is no problem. It's the worst when I pull into my driveway which is on an incline and let off the gas for a second. When the car stops moving or maybe starts to roll back a bit and I step on the gas there is a really big kick as the engine speeds up for a half second and then engages. I took it to a transmission shop and unbelievably the jolt was gone during the test drive and there were no transmission or engine codes. So after reading many very interesting and informative posts on this problem and many suggestions on the possible causes I just have one question. Has anyone out there done something that has truly fixed the problem? If so I'd like to hear it.
This is the X150 forum. You may have better luck for your specific problem on the X100 forum.
Just briefly reading through, it does not seem like you have the same issue as the OP anyway.
Old Dec 8, 2020 | 04:57 PM
Paul XK8's Avatar
My ZFHP26 has the identical problem. Did you ever find the cause?
Old Dec 14, 2020 | 04:32 PM
JagV8's Avatar
Sounds like one of The Lurch issues
Jaguar S-Type ZF Gearbox Lurch fault
Mostly fixed by newer software / changing fluid but can also be due to an engine issue you've not realised is there.
gio
Feb 9, 2021 07:27 PM
Crunchyapple1
Apr 11, 2020 02:48 AM
gio71
Jun 29, 2019 01:50 PM
Bungee
Jun 11, 2012 02:27 AM
charm11
Aug 25, 2010 11:19 AM
