Hey guys! DIY headlights change out 2014 jaguar xkr ??
Old Sep 25, 2021 | 03:40 PM
dag82's Avatar
Default Hey guys! DIY headlights change out 2014 jaguar xkr ??
Hey all
curious if anyone has tried installing new headlights bulbs on a 2014 Jaguar XK?? Removed the 3bolts as indicated. 2from top 1under wheel well cover but still can’t move the headlight. I mean it wiggles around but doesn’t completely let loose in order to change your Blub, any ideas as to what I’m doing incorrectly??
TIA
dag
Old Sep 25, 2021 | 04:58 PM
Kongo1's Avatar
Just did mine this morning so I could replace the side marker. Had the same issue at first. Disconnect the washer hose.
Old Sep 25, 2021 | 07:28 PM
steve_k_xk's Avatar
Kongo I'm gathering you have pre face lift with washer hose attached to headlight ?
Dag did you disconnect the harness before trying to remove
Old Sep 25, 2021 | 08:01 PM
Kongo1's Avatar
Correct, pre-facelift.
Old Sep 25, 2021 | 11:01 PM
u102768's Avatar
I believe on the 2012 on facelift cars that you have to release the bolts that hold the bumper on on the side that you are changing the bulb and ease it forward slightly otherwise you won't be able to fully remove the headlight,
Old Sep 26, 2021 | 06:03 AM
dag82's Avatar
Hello
no i didn’t. Had read in couple treads it wasn’t necessary to do so on our model year xk but I fully intend on trying again later today & loosening the hose in the process.
i’ll keep you all posted on how it goes!
Thanks guys really appreciate the responses
Old Sep 26, 2021 | 12:32 PM
MarkyUK's Avatar
My Indy were able to change the bulbs on my 2014 without taking anything apart, not that on my car (and probably yours) the bulbs are limely to be DS3's (same as F-type) although the on-line resources said it was DS1.
Went for osram nightbreakers and Indy didnt charge me for fitting
Old Sep 26, 2021 | 01:25 PM
Kongo1's Avatar
Most important thing when removing on the pre facelift models is to be patient and not do a lot of jiggling or twisting or you'll break the tab that lines up next to the wheel well bolt. Ask me how I know.🙄
Robert Page
Dec 1, 2025 07:39 AM
Wil
Nov 29, 2019 05:12 PM
prodigy215
Mar 11, 2016 07:01 PM
rossh
Mar 17, 2015 10:04 AM
Dennis
Sep 11, 2008 09:06 AM
