How do I change the brake light bulb?
Old Jun 29, 2011 | 06:51 PM
740ilDuke's Avatar
Default How do I change the brake light bulb?
Never thought I'd ask that one.
Do I have to remove the two cylindrical nuts off the housing and remove the whole lamp assembly? Or is there another way?
I took note of the oval shaped rubber shield and plug, but could not get it out. What is the trick? I squeezed the clips (looks like 4) and one clip snapped off, so I stopped. Do I pull on the rubber gasket?
It's the passenger brake lamp.
Thanks in advance!
Old Jun 29, 2011 | 07:06 PM
jallitt's Avatar
There are 2 nuts which need to be removed from inside the car. And there's a press-in stud near the front corner which needs to be carefully pulled out otherwise you'll end up breaking off the sharp corner of the lamp.
Then the whole lamp assembly comes out and you can access the bulb sockets from the rear. Once you know where the nuts are it only takes a couple of minutes. One is easy to find after removing the plastic "grill" from the luggage compartment - the other one you'll have to feel around for near the top on the other side of the oval rubber seal.
Old Jun 29, 2011 | 07:14 PM
740ilDuke's Avatar
Thanks! I know the backup light is a sealed unit, and people often think one is burnt out - but I wasnt sure if Jag was making the same design to sell more parts by stamping it shut.
I saw the studs today, but just wanted to be sure before proceeding. Thank you for your help.
Old Jun 29, 2011 | 07:45 PM
jallitt's Avatar
The backup lights are LEDs and will probably outlast the car
You could always do the 2010 LED taillight conversion and never have to worry about changing a bulb
Old Jun 29, 2011 | 07:58 PM
740ilDuke's Avatar
Maybe if I get rear ended! LOL.
D.K
Dec 10, 2023 02:05 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
laserguy
Sep 3, 2015 02:02 PM
OkieTim
Sep 2, 2015 12:48 PM
innzane
Sep 2, 2015 10:08 AM
