How do I know whether I have the 'dynamics pack'?
Will be changing tyres, reconditioning wheel rims, changing pads and will be taking the opportunity to do a full 4 wheel alignment. The service manual gives the various castor, camber and toe angles for various XKR models. There is a set of angles for 'Supercharged with dynamics pack' and a different set for 'Supercharged without dynamics pack'. I had the impression that all supercharged models had the 'dynamics pack' but clearly these two sets indicate otherwise. I checked my VIN against the topix database and could not find the 'dynamics pack' feature but I did have the 'super sport suspension' feature listed. Is this 'super sport' feature the same as the 'dynamics pack'?
Cheers!
BTW: if anyone wishes any particular info while I do the above tasks, feel free to ask; am not an expert but can share some experience as best I can.
Cheers!
I believe if you have wires attached to the top of the shock towers you have the 'dynamics pack'. I just looked through my 2007 brochure. No mention of an optional 'pack'. All XKR's come equipped with eCATS dynamic suspension.
I'm sure someone else will chime in.
That was my impression as well. Also, camber/toe angles weren't adjustable from what I read. I may be wrong but that was something i was told to look for when purchasing as if it's out, it's a very expensive fix.
Many things aren't adjustable according to shops that should know better. Often they should know but don't
A jag indy may well know, however, or a good ole-fashioned mechanic if you can find one.
From what I can see, toe, castor and camber are adjustable. I will assume I have the 'dynamics pack' which seems to connect to the CATS and active suspension feature. Still not sure why the service manual would list 'Supercharged without dynamics pack' though.
car5car
Feb 10, 2016 09:20 AM
cpears
Feb 3, 2016 09:24 AM
FS[SouthEast]: Supercharger kit V8
moff1959
Jan 30, 2016 06:42 AM
