How do I know whether I have the 'dynamics pack'?
Old Feb 23, 2016 | 04:12 PM
ejjbee's Avatar
Default How do I know whether I have the 'dynamics pack'?
Will be changing tyres, reconditioning wheel rims, changing pads and will be taking the opportunity to do a full 4 wheel alignment. The service manual gives the various castor, camber and toe angles for various XKR models. There is a set of angles for 'Supercharged with dynamics pack' and a different set for 'Supercharged without dynamics pack'. I had the impression that all supercharged models had the 'dynamics pack' but clearly these two sets indicate otherwise. I checked my VIN against the topix database and could not find the 'dynamics pack' feature but I did have the 'super sport suspension' feature listed. Is this 'super sport' feature the same as the 'dynamics pack'?
Cheers!
BTW: if anyone wishes any particular info while I do the above tasks, feel free to ask; am not an expert but can share some experience as best I can.
Old Feb 23, 2016 | 05:29 PM
flyc2c's Avatar
I believe if you have wires attached to the top of the shock towers you have the 'dynamics pack'. I just looked through my 2007 brochure. No mention of an optional 'pack'. All XKR's come equipped with eCATS dynamic suspension.
I'm sure someone else will chime in.
Old Feb 23, 2016 | 07:10 PM
nasomi's Avatar
That was my impression as well. Also, camber/toe angles weren't adjustable from what I read. I may be wrong but that was something i was told to look for when purchasing as if it's out, it's a very expensive fix.
Old Feb 23, 2016 | 07:37 PM
flyc2c's Avatar
Toe is always adjustable through the tie rod ends. Camber isn't technically adjustable but from what I've gathered you can do it through custom shims.
Old Feb 24, 2016 | 03:25 AM
JagV8's Avatar
Many things aren't adjustable according to shops that should know better. Often they should know but don't
A jag indy may well know, however, or a good ole-fashioned mechanic if you can find one.
Old Feb 25, 2016 | 03:44 AM
ejjbee's Avatar
From what I can see, toe, castor and camber are adjustable. I will assume I have the 'dynamics pack' which seems to connect to the CATS and active suspension feature. Still not sure why the service manual would list 'Supercharged without dynamics pack' though.
sg18438
Feb 10, 2016 12:54 PM
car5car
Feb 10, 2016 09:20 AM
cpears
Feb 3, 2016 09:24 AM
moff1959
Jan 30, 2016 06:42 AM
o1xjr
Jan 28, 2016 08:29 AM
