How much work to take supercharger off?
Old Jun 26, 2020 | 03:31 PM
AlexJag's Avatar
Sponsor
Default How much work to take supercharger off?
Anyone done this? How long does it take to remove ?
thinking of doing a rebuilt
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Jun 26, 2020 | 04:24 PM
Reverend Sam's Avatar
I'm interested to know, too. I've got the issue where the little rubber linkage thing is worn out. I figure that as long as I'm doing that, I should get the new snout with the smaller pulley. And as long as I'm doing all that I should go ahead and cut off that damn duckbill thing. My 2010 still has the old AC drain design and it's impossible to get to with the supercharger installed.
Old Jun 26, 2020 | 05:14 PM
Sean W's Avatar
The 4.2L how to is in the DIY sticky
also this from the X350 forum (4.2L again)
https://www.jaguarforums.com/forum/x...r-i-pdf-84396/
And this
https://www.jaguarforums.com/forum/x...valley-134108/
Old Jun 26, 2020 | 05:24 PM
George05's Avatar
I was quoted 6hrs labour at £65 per hour but told that could go up so would budget for $1000 , get the coupler changed whilst its off only a few dollars for the part
Old Jun 27, 2020 | 05:37 AM
guy's Avatar
guy
I don’t understand your quote. I had it removed, cleaned, oil changed and reinstalled at the dealer for 1/2 that.
furthermore, its an Eaton. A common supercharger that many shops know how to manage properly.
Old Jun 27, 2020 | 06:32 AM
80sRule's Avatar
On my x308, it took about 4 hours to R&R. But i spent probably another few hours doing valley hoses, vacuum hoses, and other miscellaneous bits because "while I'm there". The actual rebuild, assuming it doesn't need the front rotor pack bearings, is easy to do and cheap ($80) with a simple harbor freight level press. Do the snout bearings, rear rotor pack needle bearing packs and a coupler; that with oil was that like 80$on eBay.
i much prefer the torsion isolator style couplers versus the solid ones. They reduce noise a good bit with that little spring! I think i paid like 50$for a factory style coupler.
Old Jun 27, 2020 | 10:16 AM
George05's Avatar
Well done you , that is very cheap , yes we all know they are made by eaton. Here in the Uk . Is yours the 4.2 or the 5 litre car you don't say ,Please add to your signature so every one can see please
Old Jun 27, 2020 | 01:54 PM
gkubrak's Avatar
The sticky shows you all the parts I changed while I was in there.
If I had to do just the supercharger again (TB, TB elbow, intake pipes, coolant manifold, etc..), I could probably do it under 4 hours.
However, you will have access to the inter coolers, intake gaskets, and fuel injectors at that point. Your call.
Old Jun 27, 2020 | 03:57 PM
guy's Avatar
guy
Yes, where did my signature go??
... I have no idea why the presentation of the signature block seems intermittent.
Old Jun 27, 2020 | 04:12 PM
George05's Avatar
Thats better
Old Jun 28, 2020 | 06:48 AM
MarkyUK's Avatar
For SC removal/refitting my indy has quoted £1080+VAT, which is broken down as
1) 7 hours labour
2) Changing the coupler snout to a newer solid version (supplied by them)
3) Changing the SC oil (supplied by them)
4) Changing the bearings (supplied by me)
5) Changing the SC belt (supplied by them)
6) Replacing the smaller ali upper pulley with a stainless one (supplied by them)
7) Draining/flushing and replacing the coolant with Evans Waterless (supplied by me)
I cross checked all the prices and in most cases they could source the parts cheaper than I could, as they run an X150 race car running on Evans coolant they still have to get back to me on the price...but I suspect it will be cheaper than I can get it.
Old Jun 28, 2020 | 08:27 AM
DGL's Avatar
DGL
This Evans waterless coolant has my attention. What can you say about it...
Old Jun 28, 2020 | 11:08 AM
MarkyUK's Avatar
Erm, dunno it's waterless and coolant?
From what I've read engine temps increase as it has a boiling point of 180+
The benefits seem to be:
1) No pressure
2) No corrosion
3) Never needs changing
4) A leak is a gradual process, not a gusher
5) No water pump failures
Old Jun 28, 2020 | 01:03 PM
Cee Jay's Avatar
That's 180 in Celcius, or 350 Fahrenheit.
While engine temps may increase overall, the hot spots are somewhat alleviated, so the engine temperature is more uniform.
Also, Evans is legal for all drag strips where glycol based coolants are not due to slipperiness and a real mother to clean off the track.
Old Jun 28, 2020 | 01:58 PM
George05's Avatar
1) No pressure
2) No corrosion
Spilled my coffee lol
Old Jun 28, 2020 | 02:40 PM
gkubrak's Avatar
I think I would rather use 100% water to keep overall temp down. Hahahaha
Old Jun 28, 2020 | 03:43 PM
plc's Avatar
plc
1) No pressure
2) No corrosion
I Spilled my coffee as well lol
DGL
Jun 6, 2020 04:58 PM
OUScooby
Aug 4, 2019 02:38 PM
cygnus x1
Jun 18, 2014 06:29 AM
aholbro1
Aug 19, 2013 09:57 PM
jeffrimerman
May 30, 2011 06:05 PM
