how to reset after battery change
Old Sep 26, 2024 | 02:41 PM
coldpad1's Avatar
Default how to reset after battery change
installed new battery.
1. When reconnected screen showed a red and green bar. T chose green and (aged). Its been flashing and showing data for well over 1/2 hour. Did I miss or do somethinbg wrong? The sound is like when its loading a CD.
2. The back windows don't go up when I raise the top.
I read to do a hard or soft reset (various versions) like leaving a door open and disconnecting the - for 120 seconds or disconnecting both + and - cables and touching them together. I hate taking this apart again to do that if I don't have to. Also read its in the manaul and it isn't.
HELP
Last edited by coldpad1; Sep 26, 2024 at 02:59 PM. Reason: update to original post
Old Sep 26, 2024 | 03:00 PM
coldpad1's Avatar
I did the hard reset and item 1 solved that issue but the back windows do not go up when I close the top.
Old Sep 26, 2024 | 03:49 PM
Cee Jay's Avatar
Are you absolutely certain beyond any possibility whatsoever and willing to stake your life on the fact that your 'new' battery is FULLY and COMPLETELY charged?
It MUST have 12.6 volts or more or it will cause electrical problems on any of a dozen or more systems.
Batteries sit for a LONG time between initial manufacture and the retail sale. Very rarely are they fully charged when purchased.
Old Sep 26, 2024 | 03:55 PM
guy's Avatar
guy
1. Disconnect the battery from the cabling.
2. Touch the cables together to discharge any capacitance.
3. Confirm health of battery by performing a voltage reading at 12.6v
4. Reconnect cables.
5. Do not depress brake pedal, and depress and release start button.
6. Wait for all dings and chimes to finish.
7. Depress start button then press brake pedal.
Vroom... Then perform your window, etc resets.
Go for that drive.
Old Sep 26, 2024 | 03:56 PM
guy's Avatar
guy
As commonly happens, Cee Jay and I cross post.
Old Sep 26, 2024 | 04:29 PM
coldpad1's Avatar
Puting on a trickle charge to assure
Old Sep 26, 2024 | 04:35 PM
coldpad1's Avatar
How do I reset the windows?
Old Sep 26, 2024 | 04:53 PM
Cee Jay's Avatar
It's in the user manual.
Hold switch, glass stops, release switch, hold switch same, release switch.
Up, down, both sides.
Old Sep 26, 2024 | 05:36 PM
coldpad1's Avatar
I do not see it in the user manual. I looked everywhere. There is no switch for the the rear windows on the convertible. They go up with the top. The front windows work fine
Old Sep 26, 2024 | 05:58 PM
guy's Avatar
guy
By doing so, you will now need to let the battery "rest" for 6 hours. That means NOT on any charger. Any reading immediately after any charging is irrelevant.
We really need a voltage reading from a multimeter.
Old Sep 26, 2024 | 06:21 PM
guy's Avatar
guy
Incidentally, these two pages are commonly overlooked. I tend to use the "resetting the switch" option as it has the effect of powering up all modules "before" starting the engine. And that includes pressuring up the fuel rail.
Old Sep 26, 2024 | 06:57 PM
coldpad1's Avatar
I had found that page in the manual but thought it was to reset the anti trap and was referring to only the forward windows. The battery was at 95% when placed on the trickle charge. I do not have a multimeter. It's an Interstate Battery which is all I buy. My last one lasted 9 years
Old Sep 26, 2024 | 07:41 PM
kj07xk's Avatar
The rear windows won’t work until you reset the front windows.
Old Sep 26, 2024 | 09:54 PM
Cee Jay's Avatar
Your page number may vary:
Old Sep 27, 2024 | 02:03 AM
Cliffords's Avatar
I recently disconnected my battery for a few hours and had the same rear windows on a convertible problem you describe. I sat holding the close button for the top for about 60 seconds, you know how long that feels, and eventually they just came up and have worked fine since .
Old Sep 27, 2024 | 08:17 AM
coldpad1's Avatar
Windows and top up and down now - Thanks everyone. Now my new dilemma. After testing I had to reinstall the cardboard / rug covered backer board so I had to remove the luggage rack. Now I can't get it back in and get messages and top wont go down. i know its the back bar. Getting aggrevated. Anyone have pictures ?
Old Sep 27, 2024 | 08:48 AM
coldpad1's Avatar
All fixed - I'm stupid - Looked at a picture - Realized I had it upside down - LOL - I took it out and back in so many times
Old Sep 28, 2024 | 04:37 AM
coldpad1's Avatar
Windows solved. Next issue is my multi disc cd player. Read and tried removing the fuse and reinserting. Did not work. Sounds like its trying to load. Some cd's play for a few seconds etc. Any ideas?
Old Sep 28, 2024 | 09:23 AM
Cee Jay's Avatar
Try ejecting all of them and make sure nothing is gummed up inside from dirty disks?
dibbyandco
Jan 26, 2026 01:32 PM
worrasf
Jun 26, 2024 01:30 PM
Baxter3319
Jul 10, 2021 10:09 AM
Steve-in-ct
May 15, 2017 12:33 PM
scoffy
Jan 22, 2017 08:57 AM
