I do it all the time...
Old May 28, 2019 | 09:57 PM
pk4144's Avatar
Default I do it all the time...
The convertible rear window, that is.
As you can see, I did it last night. My garage ceiling is too low to raise the top, and it had started raining. So I raised it outside (manually raised the windows)... ran upstairs with groceries... and promptly forgot about it.
If you get a little impatient with the process it's actually easy to do.
Old May 29, 2019 | 06:55 AM
jagtoes's Avatar
I'm missing something here .Usually the door windows close after the side windows close so how did you close the door windows. So far I haven't done what you have experienced so I just was interested in how you do this. I usually close the top in my garage but the normal cycle won't let me do what happened here.
Old May 29, 2019 | 08:26 AM
kj07xk's Avatar
I’m guessing he doesn’t have Steve’s (aka WhiteXKR, aka theJagWrangler) remote top control, so he holds the button until the top closes and latches, then releases the button before the windows close, and then manually raises the front windows.
Get theJagWrangler.com remote top control (with rear window control is a great option), and you won’t have this problem anymore.
Old May 29, 2019 | 10:20 AM
jagtoes's Avatar
OK I guess I coulds see that move but by holding the button the rear windows go up and then the door windows go up so why stop during the cycle. Just seems strange to do it the way you mention.
Old May 29, 2019 | 12:09 PM
Cee Jay's Avatar
Lots of ways to have the back windows halfway or down, but that just shows you that YOU NEED STEVE'S TOP REMOTE!!!!
It's a one-press and leave deal, even on the interior control button. No more ghetto holding-the-button-until-you're-pissed-and-it's-not-even-done-yet scenarios.
Old May 29, 2019 | 06:55 PM
pk4144's Avatar
'Holding-the-button-until-you're-pissed-and-it's-not-even-done-yet..."
EXACTLY
Old May 29, 2019 | 07:36 PM
jagtoes's Avatar
EXACTLY
OK , I'm retired so 15 seconds isn't a problem.
Old May 29, 2019 | 07:45 PM
Cee Jay's Avatar
That means you're probably old, so your bladder is weak. Fifteen seconds can be the difference between wet trousers and NOT wet trousers.
Old May 29, 2019 | 07:52 PM
Reverend Sam's Avatar
I've had my coupe for a week, and for the life of me I can't figure out how to roll down the back windows.
Old May 29, 2019 | 08:08 PM
Cee Jay's Avatar
If you want the back windows down AND the top still up, begin the Top Down sequence and as soon as the rear windows are full down, STOP the procedure.
Old May 29, 2019 | 08:23 PM
80sRule's Avatar
You find a way and I'm all ears!
Old May 29, 2019 | 08:42 PM
Stuart S's Avatar
Coupe rear windows are fixed and don't roll down. No motors etc.,
Old May 29, 2019 | 08:44 PM
Ranchero50's Avatar
Lightbulb
Pull the door seal rubber out at the bottom of the window, remove the bolt and slide the glass forward out of the window seal. It's actually kind of neat looking. Pity that the coupe glass doesn't lower since the our chassis have the vert top framework behind the side trim.
Old May 29, 2019 | 09:00 PM
Cee Jay's Avatar
Aw, crap. I forgot that Sam cheesed-out and got the Coupe instead of 'vert.
My bad.
Old May 29, 2019 | 11:17 PM
80sRule's Avatar
I meant as a joke, but it would have been neat to roll with the glass down and out of the way. The thing is that it looks like it could have been...
Old May 30, 2019 | 06:50 AM
jagtoes's Avatar
All you need to do is tap the top button for a second and the rear windows go down with the top up. No need to start the top down cycle.
Old May 30, 2019 | 08:34 AM
Old May 30, 2019 | 10:41 AM
Cee Jay's Avatar
OK then. I'd not know that because I have the JagWrangler stuff. One tap on the top button and EVERYTHING goes down.
Course, THREE taps on the PAX window switch and the rear windows go down, so there's that...
Old May 31, 2019 | 11:38 AM
Stuart S's Avatar
davideoandthebeast
Dec 14, 2014 05:40 AM
imax6000
Mar 17, 2009 12:12 AM
Big Tex
Nov 6, 2008 10:16 PM
mgraham224
Nov 25, 2007 01:22 PM
scubayachts
May 11, 2007 09:57 PM
