iCarsoft LR 3.0 - Seat Calibration
Old Dec 21, 2024 | 08:28 PM
LJRXKR's Avatar
Default iCarsoft LR 3.0 - Seat Calibration
Hi folks, hopefully a fellow owner of the LR 3.0 can give me some pointers. My passenger seat is lacking its full range and is in need of a re-calibration. I got the LR 3.0 as apparently this can do the calibration (not keen to invest in a full SDD setup yet). I can get all the way to starting the process then get an error on the icarsoft screen saying "Communications failure. Application failed.". The seat controls work (besides seat incline), and checking the actual seat module itself shows no faults. If I go and test the module I can manually make the seat work and sit upright as it should be. Battery voltage was around 13v (on a battery maintainer throughout).
The driver's seat was recalibrated by the dealer earlier this year and works fine now. If I try recalibrating that seat I get the same error message. Any pointers?
Old Dec 21, 2024 | 11:52 PM
kj07xk's Avatar
I seem to recall, hopefully correctly, that another owner posted in a thread here somewhere, that even though the directions stated to do the calibration with the car NOT running, that he found it would only work with the car running.
Old Dec 22, 2024 | 01:47 AM
Cliffords's Avatar
I can get my seats to move about with my iCarsoft but also can't get a recalibration. My seats stop performing well after a battery disconnect and I often have to try and move them about with the software afterwards. I can put them where I want with the tool.
On the passenger seat that seemed harder to get moving ,I discovered that on the seat incline, that mine will move on it's own with the switch if you hold the switch in the position you want it to go for a period of about 45 seconds. It feels a long time and you can't think it will work but it does on mine . It suddenly comes alive .
Old Dec 22, 2024 | 08:06 AM
wymjym's Avatar
That is true for the Foxwell units, haven"t heard of others.
wj
Old Dec 22, 2024 | 01:07 PM
LJRXKR's Avatar
Thanks for the responses guys. When I'm next with the car I'll try:
1) calibration in accessory mode
2) calibration with engine running
3) holding the seatback incline switch for >45 sec and see what happens
I've also sent off an email to iCarsoft to see if their tech support can help. But don't expect anything this side of xmas.
Old Dec 22, 2024 | 08:54 PM
panthera999's Avatar
I've used my autel ap200 with the jlr download to calibrate my x150 seats. It has an intermediate selection screen in the process that requires me to choose a seat type. 16 way, 12 way, whatever. Select the wrong value and the routine fails. I don't know if your problems with the calibration routine are related to seat type selection, but it's something to look into. Of course, sdd calibrates seats, but as you bring up sdd, you're specifying the kind of seats you have through the VIN and the car configuration file. Good luck
Old Dec 23, 2024 | 07:39 AM
fritzthecat's Avatar
Here’s my link:
https://www.jaguarforums.com/forum/x...3/#post2766855
Yeah, I found ya hafta start the car and leave it running.
Rick
Old Jan 7, 2025 | 01:26 AM
LJRXKR's Avatar
Thanks everyone for the input. Sadly, none of those steps helped. I've logged the failed runs and sent off to iCarsoft so will see what they reckon.
Old Sep 14, 2025 | 03:00 AM
LJRXKR's Avatar
Just closing out this thread. iCarsoft sent me a few files to load and try and still no dice. I picked up an Autel AP200 and that worked first time with calibrating the seats.
Old Sep 26, 2025 | 07:23 PM
Cee Jay's Avatar
I just used an Autel, not really sure what I did, but the PAX seat moves now. Only took a few minutes to do......... whatever I did.
Old Sep 26, 2025 | 07:43 PM
Agreed that the autel ap200 is a bit weird to use when recalibrating the seats. Several steps make sense after the user guesses a bit but at the time seem to expect configuration knowledge the person might not have.
Old Sep 27, 2025 | 12:19 AM
LJRXKR's Avatar
I'll take it after having a seat that wouldn't incline!!
Glyn Richards
May 8, 2024 09:14 AM
knares
Feb 21, 2024 07:53 PM
claytoncramer
Mar 11, 2023 08:47 PM
toomanyjags
Jan 3, 2016 01:29 PM
EJ Garity
Aug 17, 2015 12:09 AM
