IDS_SDD Deep Dive - IDS\XML\IVS-AsBuilt
Old Nov 3, 2022 | 08:21 PM
Bill400's Avatar
Default IDS_SDD Deep Dive - IDS\XML\IVS-AsBuilt
Hello SDD fans, fellow computers nerds and wanna-bees,
I'd like to share some SDD deep dive experience. I find it interesting and hope that some of you do too!
SDD scans your vehicle when it is "connected", and stores a copy of the "as-built" and "as-ordered" module and software inventory on your laptop.
The location is ProgramFiles\JLR\IDS\XML\IVS-asbuilt (or just IVS in newer versions). The file name is (your_VIN).xml.
Since it is an .xml file, it can be opened and examined using windows explorer. Just exit without saving unless you are intending to make a change.
The file lists module anconyms, CAN node IDs and software for each module in the target vehicle.
Acronyms with module names for a typical 2011 XK follow, XKRs are similar, as are other Jaguars of similar vintage.
AAM = Audio Amplifier Module node_id>0x784 part_number type="WERS">7W8M-18C808-AB
ABS = Anti-lock Brake System node_id>0x760 part_number type="WERS">8W83-2C405-CC
ACM = Audio Connectivity Modulenode_id>0x784 part_number type="WERS">8W83-18C815-AC
APIM = Accessory Protocol Interface Mod node_id>0x784 part_number type="WERS">8X23-18C941-BA
BCM = Body Control Module node_id>0x726 part_number type="WERS">8W83-14B476-AD
BCMB = Body Cont Mod “B” node_id> Mod0x7B7 part_number type="WERS">8W83-14D628-AD
DACMC = Digital Audio Control Module C (HD Radio) node_id>0x784 part_number type="WERS">7W93-19C034-AE
DDM = Driver Door Module node_id>0x740 part_number type="WERS">BW83-14B531-AA
DSM = Driver Seat Module node_id>0x744 part_number type="WERS">8W83-14C708-BC
FACP = Integrated Control Panel node_id>0x7A0 part_number type="WERS">9W83-18C858-BA
FCDIM = Front Control Display Interface Module (Touch Screen Display) node_id>0x784 part_number type="WERS">9W83-10E889-AB
GSM = Gear Selection Module node_id>0x732 part_number type="WERS">8W83-7E453-BE
HCM = Headlamp Control Module node_id>0x734 part_number type="WERS">8W83-13K031-AD
ICM = Infotainment Control Module node_id>0x784 part_number type="WERS">9W83-19C059-BA
IPC = Instrument Panel Cluster node_id>0x720 part_number type="WERS">9W83-10849-AE
MRCM/FTCM = Movable Roof Control Module node_id>0x787 part_number type="WERS">8W83-13B524-AB
NCM = Navigation Control Module node_id>0x784 part_number type="WERS">AW83-10E887-AB
PAM = Parking Aid Module node_id>0x736 part_number type="WERS">9W83-15K866-BB
PBM = Parking Brake Module node_id>0x756 part_number type="WERS">8W83-2C496-AC
PCM = Powertrain Control Module node_id>0x7E0 part_number type="WERS">8W83-12A650-YAF
PDM = Passenger Door Module node_id>0x741 part_number type="WERS">BW83-14B533-AA
PSM = Passenger Seat Module node_id>0x7A3 part_number type="WERS">8W83-14F316-BC
RCM = Restraints Control Module node_id>0x737 part_number type="WERS">9W83-14B321-BG
RFA = Remote Function Actuator (KVM) node_id>0x731 part_number type="WERS">AW83-19G481-AA
SARM/SRM = Sat Audio Radio Mod node_id>0x784 part_number type="WERS">8W83-18C963-AD
SCME = Driver Climate Seat Module E node_id>0x776 part_number type="WERS">9W83-14F268-AB
SUMB = Adaptive Damping Cont Mod node_id>0x786 part_number type="WERS">8W83-18B008-AG
SODL = Side Object Detection Left node_id>0x7C4 part_number type="WERS">9X23-14D455-CD
SODR = Side Object Detection Right node_id>0x7C6 part_number type="WERS">9X23-14C689-CD
TCM = Transmission Control Module node_id>0x7E1 part_number type="WERS">9W83-7Z369-FA
TEL = Bluetooth Telephone Module node_id>0x784 part_number type="WERS">9W83-10D893-EC
TPM = Tire Pressure Monitoring Module node_id>0x751 part_number type="WERS">9W83-1560-AB
Z-RCCM = Restraints Control Module node_id>0x733 part_number type="WERS">9W83-18D493-AD
Correction: SODL/R were added to the OEM XK file. Typical for XF/XJ, it is not normally found in the XK.
If you would like to know more or share what you know about the inner-workings of IDS-SDD, lets hear from you.
Bill
Old Nov 3, 2022 | 08:42 PM
Cee Jay's Avatar
Cool, I saved your text into my Jag folder for later perusing.
Old Nov 5, 2022 | 05:38 PM
Speedmaster's Avatar
Super neat and interesting but way beyond my skill set. Glad to know someone is doing the heavy lifting to learn this stuff.
Old Nov 6, 2022 | 08:35 PM
Ranchero50's Avatar
So can you change the SDD and add things like headlamp steering? Mine accidently booted up with that enabled last year and I about wrecked turning onto my street because I was watching the lamp swiveling instead of the curb.
Old Nov 8, 2022 | 05:15 PM
hafren's Avatar
Bill
If you run the network integrity test (begin a diagnosis session and enter electrical/network/bus fault [iirc]) found in recommendations "module information - Network integrity test" you can obtain a lot of information about each module including software and hardware WERS #'s, module serial #'s and whether a module stores the VIN.
File Type: xlsx
Old Nov 10, 2022 | 09:13 AM
Bill400's Avatar
Lindsay,
Thanks for bringing up Integrity Test and presenting in Excel.
That reminds me that I what to find detailed info on the WERS format.
I think combining the information will make and interesting read.
2010XFS
Nov 5, 2022 09:02 PM
03Xtype
May 16, 2016 09:57 PM
hafren
Aug 18, 2015 10:46 AM
arthurdaley
Jan 3, 2013 11:04 AM
Novo
Jun 27, 2011 08:22 AM
