Inspection woes
Old Aug 15, 2017 | 10:36 AM
nasomi's Avatar
Default Inspection woes
I took the jag in for inspection and it has a couple issues.
First is needing a new cat. Jaguar replacement is $1400. Can anyone recommend a cheaper alternative?
Second is the 3rd brake light. It's LED, so it shouldn't be an issue. However it is getting no power, and all fuses are intact. All other lights work. Any idea what could be causing this?
Also new tires, but I was expecting that.
Old Aug 15, 2017 | 10:46 AM
Cee Jay's Avatar
As for the 3rd brake light, mine stopped working but I found a burned out diode on that little in-line circuit board inside the boot liner. I soldered on a replacement and it's been perfect ever since. It was nowhere near as big a job as it sounds. Maybe your problem, maybe not. A diode costs pennies, a new board is unavailable and a new light assembly is hundreds.
As for Cats, look here:
https://www.jaguarforums.com/forum/x...-2-xkr-187033/
Old Aug 15, 2017 | 03:49 PM
nasomi's Avatar
Thanks, I'll check out the board. I really don't want to chase all the wires further so hopefully that's it.
Old Aug 15, 2017 | 03:57 PM
Ranchero50's Avatar
Magnaflow sells replacement cats with the down pipe for $370 ish or $550+ with the Cali certs which you shouldn't need
https://www.summitracing.com/search/...rder=Ascending
Old Aug 15, 2017 | 04:37 PM
jagtoes's Avatar
Why did they say it needs a new cat. How did they determine that. Also what is the warranty on cats. Is it mileage or years.
Old Aug 15, 2017 | 05:05 PM
Cee Jay's Avatar
From the Google...
Catalytic Converters are emission control devices which are designed to last the life of the vehicle and do not normally require replacement. Furthermore, if the vehicle is properly used and maintained, original converters are covered by the emission control warranty for 8 years or 80,000 miles.
Old Aug 15, 2017 | 05:15 PM
steve_k_xk's Avatar
Excuse my ignorance but what is the cali certs ? Is there a difference in the cell count from either
Old Aug 15, 2017 | 05:55 PM
davchr's Avatar
In an effort to maximize public sector employment, California legislators tax, and regulate everything imaginable, and some un-imaginable things. I put catalytic converters in the un-imaginable category.
Without a "California Certified" stamp on replacement cats the inspection station will not do a smog test on your car. There are a few exceptions if you can prove they were replaced before the law went into effect. Bottom line is you get to pay a few hundred dollars extra for the "California Certification" on your cats if you live in California and want your car smog tested.
Another reason I am glad that I don't live in California anymore.
Old Aug 17, 2017 | 05:28 AM
nasomi's Avatar
The cat is rattling and not sealing correctly with the flange creating a leak. You can hear it when you get on the gas.
I'll get the car back and get it in my garage. Problem is it's so low, it's hard to get to.
Old Aug 17, 2017 | 07:18 AM
mosesbotbol's Avatar
Since you are replacing the cats, consider a complete exhaust system from the cats, back.
Old Aug 19, 2017 | 11:37 AM
Ranchero50's Avatar
Rattling means the ceramic has broken down and you'll run the risk of clogging or it'll rattle all the way back to the muffler. The ceramic is wrapped in a glass pad and the shell squeezes the pad to hold the ceramic in place.
Old Aug 19, 2017 | 11:48 AM
SinF's Avatar
I had similar issue happen on my SL. You could get after market replacement, but in my experience these drop-in cats don't last. I suggest using OEM parts if you anticipate to own it for more than couple years. Alternatively, if where you live isn't smog testing get a complete high-flow exhaust from reputable performance shop. It will be louder than OEM and will unlock some extra HPs, but will always be problematic for any smog test.
I suggest you shop around online for OEM part yourself. I guarantee that dealership isn't giving you the best price @ 1400. If you come to them with "look here I found this part for $1000" they might price match it.
Old Aug 19, 2017 | 01:24 PM
Mufc's Avatar
$1092 at Parts.com genuine Jaguar
michaelodonnell123
Sep 17, 2017 10:08 AM
