installing new battery
Old Nov 14, 2020 | 02:38 AM
  #41
wsn03's Avatar
Originally Posted by jahummer
I would never have any sort of charger or maintainer stored inside the car while connected to the mains, too many things could go wrong especially in the likely scenario of this being left unattended. I reckon that is why the manufacturers also advise against this practice.
I've been leaving mine in the boot with boot open. General consensus is close boot. Now I've bought an extension I'll use it to travel from battery to outside, then CTEK to mains (if its long enough)
Old Nov 14, 2020 | 06:39 AM
  #42
jagtoes's Avatar
I had never seen my Ctek ever get hot to the touch but I had read of other brands that have heated up and short out. Because of this I had mounted an outside plug and kept the Ctek mounted on my metal lift. Just my personal taste.
Old Nov 14, 2020 | 06:46 PM
  #43
ralphwg's Avatar
I have my CTek mounted to a work bench on the opposite side of the XK.. The battery is on the left, the CTek on the right.
Old Nov 15, 2020 | 02:31 AM
  #44
MarkyUK's Avatar
Lol, I wimped out on battery change and let my Indy do it at first service in Dec 18. Luckily I had a type 19 with high output in the garage which still had over 3yrs warranty left (taken from my old x100 that was written off). They didn't charge me for this.
As to CTEK I've always used an extension lead with it in the boot with tailgate shut and car locked*. The MXS 5.0 doesn't get warm on normal recharge only on recon mode.
*And yes neighbours have asked if it was electric...even with no backbox so it sounds like a diety gargling on startup
Old Nov 15, 2020 | 09:57 AM
  #45
KrazyIvanUSA's Avatar
Originally Posted by Stuart S
If you use a Memory Saver that attaches to your OBDII connector, you won't lose ANY settings - fuel trims, radio presets, seat memories, etc.
The guy in that video. He could be Rick Grimes little brother.
Blepore35
Jun 10, 2024 06:28 PM
vonhaaas27
Mar 9, 2020 05:48 AM
robert53
Mar 8, 2014 02:34 PM
jjf
Jan 4, 2013 12:45 PM
PERFORMANCE RED
Oct 24, 2007 09:53 PM
