iPhone 4S won't dock after using charger converter
Old Jul 28, 2013 | 02:18 PM
Byte Me's Avatar
Default iPhone 4S won't dock after using charger converter
I recently bought a Cable Jive charge converter
Amazon.com: CableJive dockStubz+ Charge Converter and 30-pin Pass Through Adapter for iPhone, iPod, and iPad: Electronics Amazon.com: CableJive dockStubz+ Charge Converter and 30-pin Pass Through Adapter for iPhone, iPod, and iPad: Electronics
so that my iPhone 4S would charge as well as play through the audio system. It worked as advertised for the first week or so, however, while it still charges my phone it will no longer connect to the audio system. While bluetooth still works just fine now the iPhone won't dock no matter if the converter is in line or if I simply try and connect the Jaguar cord directly to the phone (i.e. converter NOT in line). The dashboard display just reads iPhone Docking... and will occasionally error out and change to "dock iPhone" as if it's not connected even though it is.
Since this started it hasn't docked again, at all. I've never had a problem docking the phone prior to this.
Any ideas?!?
Old Jul 28, 2013 | 06:04 PM
ralphwg's Avatar
Two thoughts: 1. Reboot the Iphone & 2. Delete your phone from the XK and try starting all over again.
Old Jul 28, 2013 | 06:05 PM
Ngarara's Avatar
Originally Posted by Byte Me
... so that my iPhone 4S would charge as well as play through the audio system.
My iPhone 4 charges as well as plays with the standard cable - my car is Sep 2010, though it is an MY11 spec. I'm not sure if MY10 cars should charge or not, or whether the 4S is compatible with either model. The MY11 manual only talks about iPods.
One possibility is that there is a fault in the portable audio interface. Mine went on the fritz about a month ago, for absolutely no apparent reason; it stopped charging (I kept getting an 'accessory not compatible' message on the iPhone), and I lost the left channel on the audio. The dealer tried swapping the cable, but that didn't work, so they replaced the interface module under warranty. Perhaps your module has always been faulty (hence the lack of charging), or perhaps the aftermarket interface has fried it.
Sorry, not terribly helpful, but my experience is that the portable audio interface module is a bit flaky.
Old Jul 29, 2013 | 11:28 PM
Muddydog's Avatar
I can't think of why the charge converter would have anything to do with it. Just coincidence, I think. I agree with rebooting the iPhone and make sure your iOS is up to date. Any luck?
Old Jul 30, 2013 | 11:41 AM
Byte Me's Avatar
Rebooting the phone was the first thing I tried - didn't work. IOS is up to date. The other odd thing is that the speaker won't work on the phone, no more speaker phone or any noises at all for email alerts, what have you. I'm thinking that the phone thinks it's docked already and will try and clean off the contacts on the charging port to see if that helps at all.
Old Jul 31, 2013 | 04:48 PM
ralphwg's Avatar
Maybe your phone is faulty. Have you tried to pair with another car? If that works, then the problem lies somewhere in the Jaguar/Iphone connection realm. Also give serious thought to taking the phone back to Apple. I had a similar issue last year with a 4S and my XK. The service manager at my dealer said that he had seen three or four people with a similar issue and that it turned out that the phone was the culprit.
End of the day Apple supplied me with a new phone - result - no more issues.
Old Jul 31, 2013 | 06:18 PM
Byte Me's Avatar
Turns out it was most likely the phone. Talked to AT&T today, they couldn't fix, it has stopped holding a charge as well. The speaker doesn't work so no speakerphone, notifications via sound, etc. So since I was eligible for an upgrade I got a 5. Now just have to replace all my 4S accessories. Thanks apple.
Old Jul 31, 2013 | 11:31 PM
Muddydog's Avatar
I think the lightening adapter is better anyway. You'll love the camera over the 4S. Here's a consolation link: https://www.jaguarforums.com/forum/x...ashtray-95251/
Bobmac
Nov 26, 2024 03:56 AM
StealthPilot
Aug 6, 2015 10:56 PM
bocatrip
Jul 13, 2015 02:59 PM
Cambo
Jul 9, 2015 11:56 PM
emaraszek
Jun 7, 2013 12:55 PM
