Jaguar xk 2013 wont start After accident
Old Oct 31, 2020 | 09:43 AM
meinmobile17's Avatar
Default Jaguar xk 2013 wont start After accident
Jaguar XK 2013 wont start after accident...
can someone help? Where I can find the inertia switch?
Old Oct 31, 2020 | 06:43 PM
ralphwg's Avatar
We could be of more help if you were to describe exactly what is happening when you attempt to start your XK.
Old Oct 31, 2020 | 09:59 PM
Stuart S's Avatar
This article applies to the X100, but it might also apply to your X150 (2013 XK).
JagRepair.com - Jaguar Repair Information Resource
Old Oct 31, 2020 | 11:24 PM
Cee Jay's Avatar
Similar problem, no real solution:
https://www.jaguarforums.com/forum/x...k-start-80310/
Old Oct 31, 2020 | 11:49 PM
Cee Jay's Avatar
Also, look for "Fuel Pump Driver Module" or otherwise "FPDM", it's what controls the Fuel Pump. It's in the rear on the tank mount.
Old Nov 1, 2020 | 01:53 AM
Ignition comes on, but no chance to start the engine, also no starter noise. Driver airbag is deployed. Yesterday connected to the computer - error B10A2 (communication problem in the control unit: engine)
Old Nov 1, 2020 | 03:12 AM
thank you, but cannot find it there...
Old Nov 1, 2020 | 06:33 AM
thierry_1500's Avatar
More details on the accident and it’s mechanical consequences would be useful as mentionned above...
Anyhow, more and more modern cars do no more have physical inertia switches, that function is included in the restraints control module:
https://patents.google.com/patent/US6640174B2/en
can you still lock the car? If so, try double locking/unlocking, it may help the RCM calm down...
Old Nov 1, 2020 | 06:37 AM
427MikeB's Avatar
Is there a warning message on dash? Here’s a reference from the workshop manual, but it suggests it should reset with ignition on off
INERTIA SWITCH TRIPPED
Amber warning triangle illuminated LCD.
Message appears when the crash status signal from the RCM (restraints control module) changes to crash detected or a fault in the restraints system prevents the message from being transmitted.
RCM can be rest with an ignition on/off cycle. If fault has occurred, then investigate cause of fault and interrogate the RCM for faults and diagnose using a Jaguar approved diagnostic system
Old Nov 1, 2020 | 08:49 AM
SBS's Avatar
SBS
Default Did your bonnet air bags go of?
If they did then it's the two black "V" shaped switch When they are apart this cuts all power to the car. A simple cable tie pulling them together will allow the power to the car.
if the bonnet bags did go of and you are un sure of what I am trying to explain, let me know and I will post a photo of the switch I am talking about.
Old Nov 1, 2020 | 09:39 AM
Sean W's Avatar
Download the workshop manual and electrical diagrams here.
From the workshop manual B10A2:
"Refer to the electrical circuit diagrams and check restraints control module pulse width modulated SRS signal line circuit, hard wired connection between engine control module and restraints control module for short circuit to ground, short circuit to power, open circuit. Repair circuit as required, clear the DTC and retest."
To clarify or speculate on what this means, there is likely no inertia switch like those of older models. There isn't one in the EPC so I don't think it exists. It's an SRS circuit that needs to be corrected before the signal is completed.
Old Nov 1, 2020 | 09:40 AM
Sean W's Avatar
yes please post pic if you are available.
Old Nov 1, 2020 | 10:05 AM
SBS's Avatar
SBS
Ok, if your bonnet air bags go of then this black pair of switches will separate into a V shape (screwdriver pointing). They are spring loaded. When they do spring out it will cut all power to the car.
in the second picture you can see I used a cable tie to keep them together while I was doing a job on the car with the air bags removed from there located positions. This allowed the all power to the car so it could still be started and operated as normal.
Hope this helps some one understand a little more.
Old Nov 1, 2020 | 10:13 AM
Cee Jay's Avatar
Hahahahahaaaa...... Pedestrian System strikes again.
I am SO glad I don't have this.
Old Nov 1, 2020 | 10:23 AM
SBS's Avatar
SBS
... deleted
Old Nov 3, 2020 | 12:16 AM
SBS's Avatar
SBS
So I am assuming that the pictures I posted for you helped you then? Your welcome.
Old Nov 3, 2020 | 09:49 AM
Sean W's Avatar
who knows? the OP has yet to respond.
Old Nov 3, 2020 | 10:13 AM
SBS's Avatar
SBS
it was you who asked me, not the op mate.
Twilight zone time
Old Nov 3, 2020 | 10:16 AM
Sean W's Avatar
for the benefit of the forum, not for me, but also, note the thanks given at the bottom of your pic post.
Old Nov 3, 2020 | 11:12 AM
jahummer's Avatar
Do they have the pedestrian system in Germany?
