Sponsored by: DashLynx
XKR 2009 passenger seat recline
Old 04-20-2018, 12:22 PM
Panayiotis's Avatar
Default XKR 2009 passenger seat recline
the seat is reclining but not enough to be comfortable when you sit and when I am moving the seat very back until one point the back rest is moving front
robtroxel (04-20-2018)
Old 04-20-2018, 01:04 PM
Stuart S's Avatar
Received 6,141 Likes on 3,384 Posts
That's normal. Follow these steps:
1. From the outside of your car, move the seat bottom all the way down and forward. That will allow you to set the seatback to the maximum recline angle.
2. With the seat fully forward, move the seatback all the way down until it stops.
3. Move the seat backwards while watching the seatback angle. As you approach the limit of rearward travel, you will see the seatback move forwards, reducing the recline and becoming more upright.
Now that you know how it works, get in the car and find a comfortable seat position together with adjusting the steering wheel reach and angle and outside mirrors. Set the seat memory to remember those settings. Read your Owner's Handbook.
Hope this helps.
Old 04-20-2018, 05:17 PM
pwpacp's Avatar
Spot on Stuart!
The same applies to your passenger, should they have the same issue (minus the steering wheel, of course).
Old 04-20-2018, 06:44 PM
Stuart S's Avatar
If your passenger gives you a hard time, ...
The following 4 users liked this post by Stuart S:
007XKR (01-18-2021), 110reef (01-16-2021), pwpacp (04-20-2018), ralphwg (04-21-2018)
Old 04-21-2018, 04:58 AM
Panayiotis's Avatar
Hope this helps.
when i m moving the seat forward the seatback it still not going back to more comfortable
Old 04-21-2018, 06:32 AM
jagtoes's Avatar
Received 1,836 Likes on 1,231 Posts
You will need to continue to experiment with various adjustments. You may find that you will not find your optimum position and will need to either make due with what you have or end up selling it and moving on. Unfortunately the structure design has made limitations to seat position . Good luck
Old 04-21-2018, 08:49 AM
Panayiotis's Avatar
The driver seat the back rest is going a lot more back than the passenger. The passenger seat is going front a lot but back is going until upright position.
Old 04-21-2018, 04:23 PM
Ranchero50's Avatar
Doe the seat back hit the inside of the car or is it binding mechanically?
If it's hitting the inside of the car there is nothing to be done except move the seat forward and then recline it further. It's a poor design mechanic due to the convertible roof structure that even the coupe owners got stuck with. Eventually I want to cut mine apart and redo the interior panels so the seat will recline like normal.
10XKR (04-21-2018)
Old 04-21-2018, 05:02 PM
sov211's Avatar
Received 2,134 Likes on 1,308 Posts
If the seat back is not moving properly then the seat module needs to be reconfigured by the dealer. This has been discussed multiple times in other threads.
Old 04-21-2018, 06:58 PM
Received 4,436 Likes on 2,421 Posts
What he said
Old 04-21-2018, 08:08 PM
10XKR's Avatar
Yeah, whats up with that? How come no one has made a "convertible quarter panel delete" for the Coupes!
Cheers,
Dave
Old 12-25-2020, 08:57 AM
Lord_Eduard's Avatar
Sorry for bringing this topic from the ashes. But before posting new theme regarding this issuse, this is EXACTLY mine problem too (I have coupe). Did you manage to solve it? Is there any way to reset passenger seat motors, tilt position?
Old 12-25-2020, 12:19 PM
Cee Jay's Avatar
Received 5,160 Likes on 3,090 Posts
Yes. Go to the dealer. They will reset the seat module.
Or, find someone who has Jaguar SDD software and have them do a seat module reset.
ralphwg (12-25-2020)
Old 12-25-2020, 01:42 PM
Ok, I'll try to find someone. But before I do, is there anything that I could do to reset the module, like some button combination or unplugging the battery?
Old 12-26-2020, 01:02 AM
peterv8's Avatar
Do a hard reset!
detach the pos and neg on battery, hold them together for 20 seconds and reconnect.
Old 12-26-2020, 01:34 AM
Cee Jay's Avatar
Originally Posted by peterv8
Do a hard reset!
While this works for many problems, it doesn't help with the messed up seat modules. It's a known deal, and it's always a recalibration.
Lord_Eduard (12-26-2020)
Old 01-16-2021, 08:44 PM
Hazmat1075's Avatar
Stuart, The Seat Module bracket attached to the seat is broken. All works, but the case is just hanging loose. Where can I get a case or a new module (don't want to replsce it). 2005 Jag XK8. Just bought it yesterday. Part number LJE160AB/XXX
Old 01-16-2021, 09:40 PM
Stuart S's Avatar
Hazmat 1075,
You're in the X150 Forum, for 2007 - 2015 aluminum-body XK/XKR models. Your 2005 XK8 is the previous X100 steel-body model. I doubt that the seat brackets are the same. You should ask in the X100 Forum.
Regardless, try searching Ebay for what you need. You can also try Forum sponsors who sell parts, such as .SNG Barratt.
Good luck!
Stuart
GGG (01-18-2021)
Old 01-16-2021, 10:20 PM
Hazmat1075's Avatar
Thank you. The Forum is new to be and not too say with all "x" so thank you. The Module housing is made of plastic which the reason it broke of the two screws. The good thing is that it works,
Old 01-18-2021, 06:13 AM
GGG is offline
Received 16,799 Likes on 12,168 Posts
Welcome to the forums Hazmat1075,
I was going to move your question to X100 forum but thought you may never find it again!
Broken the lid of the Seat Module is a regular issue on the X100. It's available separately from Jaguar:
Please make your subsequent posts in X100 forum:
https://www.jaguarforums.com/forum/xk8-xkr-x100-17/
Quick Reply: XKR 2009 passenger seat recline
