Jaguar XKR 4.2 Engine Parts
Old Jul 24, 2023 | 07:42 AM
Squire's Avatar
Default Jaguar XKR 4.2 Engine Parts
Hi everyone,
Can you recommend any part suppliers that ship worldwide? I currently live in Abu Dhabi, UAE and my garage has given me a long list of things that they require to fix the engine on my 2007 XKR 4.2, however they can't find the parts here.
Piston over size 50
Piston ring over size 50
Valve seals
Valve guide
Main bearing
Connecting rod bearing
Thrust washer
Timing tensioner 4 pcs
Timing cover gaskit
Main pully seal
Main seal
Fly wheel seal
Oil pump
Timing chain guide 4 pcs
Engine mounting 2 pcs
Gear mounting
Converter seal
Tapit cover gaskit
Solonide valve seals (in tapit cover)
Plug seals
Spark plugs
Intake gaskit
Injector rings
Exhaust gaskit
Oil filter body o rings
Engine fan motor
If you can recommend somewhere that stock the above and ship internationally, it would be a great help.
Keith
Old Jul 24, 2023 | 09:23 AM
jahummer's Avatar
Might try SNG Barratt in the UK
https://www.sngbarratt.com/English/#...&saveBranch=UK
David Manners spares
https://www.jagspares.co.uk/
And Rimmer
https://rimmerbros.com/Category--Jag...MaAj1IEALw_wcB
Old Jul 24, 2023 | 09:24 AM
Squire's Avatar
That's great, i'll give them a try!
Much appreciated
Keith
Old Jul 31, 2023 | 07:40 AM
fritzthecat's Avatar
Wow, that’s quite a list. It might be easier to find a good used engine with low miles.
Old Aug 2, 2023 | 02:56 PM
steve_k_xk's Avatar
The block will need to be re sleeved or a general clean up of the bores and standard piston to be fitted if still in spec no one offered 50thou over unless you find a manufacturer that will be able to go custom . (5l have the option of obtaining over bore )
in regards to the main bearings there will be a good on your block as to which combination as there as 3 different 'colours' available for the xk/xkr (same crank)
Whilst the principal of rebuilding ICE are the same I would only let someone with previous experience on go near these and having said that if they are competent sourcing the parts will be very very time consuming.
The time it takes rebuilding and price weigh up the option of a) second hand engine or b) obtaining a short block from jaguar (usually around 10-12k USD ) and use existing heads .
What's the reason for this rebuild have you lost compression in one or more of the cylinders?
thomas2
Apr 12, 2018 04:55 PM
Reggie's Dad
Aug 16, 2014 06:55 AM
o1xjr
Mar 30, 2014 05:15 AM
daddyo007
Apr 6, 2012 03:50 PM
kdross
Sep 8, 2010 08:42 PM
